03-05-2013, 05:38 PM | #1 |
Rep 53
Tire size consensus for 8 and 9.5x19 ZCP wheels
I was thinking 245 35 19 and 275 30 19.
Comments? Justin Last edited by sprbxr; 03-06-2013 at 04:51 PM.. |
03-05-2013, 05:58 PM | #2 |
Not a New Member
94
Rep 925
spot on, sir!
if you're careful... some tire brands have 285's that fit 9.5 widths, but you may have to do some research to see which ones work for you. Hankooks for sure have them. however, if you're doing any susp mods, 275 is pretty much the max.
08-21-2013, 11:29 AM | #3 |
Rep 370
Drives: 2007 BMW Z4MC
Garage List 2007 BMW Z4MC - Sold [7.66]
2006 330ci ZHP [0.00] 2000 Porsche Boxster S [0.00] 1972 DeTomaso Pantera [9.50] |
OK, I'm doing some of this same research. I have the same rims (ZCP). The issue is that I need to run PSS's (I'm sold on those!), and they do NOT have a 285/30. I currently have Hankook 285/30 and 245/35's. Really like the look, but the Hankook's need to go. My options in PSS are:
1) as stated above, go with a 275/30 in the back and the same 245/35 in the front. Problem is, the rear tire height is now lower than the front. perhaps not enough to notice. 2) go a little taller, and stay with a 285/35 in the back, and a 245/40 in front. May cause rub issues if I lower? anyone done this combo? 3) go to 275/30 in back, but use a 235/35 in front. That way the front and rear tire height is a closer match. Anyone running any of these combos? appreciate any feedback... |
08-21-2013, 12:25 PM | #4 |
Rep 12,565
245 seems wide for 8", i'd go 235 max
