08-30-2017, 02:48 PM | #1 |
Rep 93
Is this a good deal? Z4M
Hey, check out this car I found on Cars.com: https://www.cars.com/vehicledetail/d...ff=share_other
Anyone in Seattle area to test drive this bad boy? Ill pay you for your time. |
08-30-2017, 02:55 PM | #3 |
Rep 158
Drives: 07 Z4 M Coupe
Not sure what the market is for the Roadsters, I recently purchased a coupe. It looks like a nice ride to me, and I do like the color combo..
Good luck.. hope you find what you're looking for! |
08-30-2017, 03:07 PM | #4 |
Get off my lawn
932
Rep 1,159
Drives: 6MT
Garage List 2023 GR Corolla [0.00]
2022 BMW X3 M40i [10.00] 2007 BMW Z4M Coupe [0.00] 2002 BMW 325xiT [0.00] 1991 BMW 318is [0.00] |
There are deals to be had on this website and the BMWCCA classifieds section, some of which are more appealing in my opinion.
Hard to tell what kind of past a car had once it enters a used dealership lot. Pre-purchase inspection necessary certainly and a thorough once-over. |
08-30-2017, 04:27 PM | #5 | |
Rep 93
Other coupes i found goes up on the 30k |
08-30-2017, 09:09 PM | #7 |
Rep 232
Nice roadster. I picked up a black sapphire / imola combo this summer.
27k on the clock for just under $24k. I think I got a good deal but that's irrelevant, she is a joy to drive and look forward to every weekend drive. GL |
08-30-2017, 09:12 PM | #8 |
Rep 870
Drives: 2006 BMW Z4M Roadster
Price is pretty good if it doesn't have issues, but at 75K, if it hasn't already been done, you may be looking at valve adjustment, vanos rebuild/refurb swap, rod bearings, total fluid replacement, bushings, suspension, guibo, etc. All of that done at an indy shop can run into $5K+ range. I'd want to know if any of the above had already been performed. Also, just from my personal experience, run both seats all the way forward, and find the slit in the carpet behind the seats. Run your hand up under there and feel around. If it is wet, the car leaks. If dry, you're good to go.
Salty
VPGNS117.00 |
08-30-2017, 09:14 PM | #9 | |
Rep 870
Salty
09-01-2017, 06:48 AM | #10 |
Rep 12,309
Identical car to my Roadster. Airbag light is on (mine is too). One of the best color combos IMO. As long as the car checks out and doesn't need too much, I'd say it's a good deal. Not many cars I'd rather have under $20k
09-01-2017, 08:36 AM | #11 |
dances with roads
4722
Rep 4,096
I believe I read somewhere that the airbag light can be due to the seat sensor being damaged. I recall something like kneeling on the seat can damage the sensor. Not a problem in the coupes!
09-01-2017, 10:20 PM | #12 |
Rep 232
I believe you are correct sir. Previous owner mentioned this to me and told me not to let anyone keel on the passenger seat since he had changed the seat sensor.
09-02-2017, 01:14 AM | #13 |
Rep 820
Drives: 2007 Z4MR silver grey
Code the passenger occupied airbag sensor to "not active". It will tell the computer to ignore the sensor and will make the passenger airbag active at all times. If you need to turn it off for a child in the seat, use your key in the on/off switch on the side of the dash. Once coded to off, you unplug the sensor cable under the seat. You can clear the error code and the light will go off. Obviously this takes coding software, or you can outsource it as I did.
