      10-12-2011, 05:20 PM   #1
blender
Custom User Title
blender's Avatar
Drives: black
z4 Door panel removal
Bavarian sound works video showing door panel removal steps in prep for speaker upgrade. I followed these steps to replace door switch mechanism. The plastic studs used as door clips are easy to bend/break, but they slide out for easy replacement. I recommend buying a few in you plan on pulling the door panel.
StickMon636.00
      10-22-2011, 10:23 PM   #2
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
Which clips are you referring to? The ones on the top edge, or on the lower and front perimeter?
      06-01-2019, 05:02 PM   #3
theinvid
Drives: BMW Z4 3.0i 2006
Is it possible to remove just the leather insert portion of the door panel as opposed to the entire door panel in order to paint/stain the leather piece?
      06-02-2019, 01:46 AM   #4
StickMon
StickMon's Avatar
Drives: 2006 MR
Lower and front perimeter.
Lower are white, front are yellow.
Different lengths.
Buy 'em by the sack!
https://www.ecstuning.com/b-genuine-...h/51418224768/
https://www.ecstuning.com/b-genuine-...h/51417056298/
      06-08-2019, 02:47 PM   #5
WestCDA
Drives: 2006 Z4R 3.0si
No, though it's possible to remove the leather insert panel once the door panel is off.
It's a pain, as you have cut/grind a few miles of plastic welding to remove that insert section.
Tags
door panel
