Go Back   ZPOST > BMW Z4 Roadster and Coupe > Regional Forums > Canada
      05-09-2009, 02:15 PM   #1
mazzawi
Drives: before 05 Z4 2.5 now 08 MRdstr
2005 Z4  [5.00]
GTA track anyone?
Drivers,
This is a reminder that DIG is hosting our first Open Lapping event of the 2009 season at Dunnville Autodrome on NEXT WEEKEND Sunday, May 17th!
We still have quite a few slots available for this event – get ‘em while they’re hot. (or something)
Also!! For the first time ever we will be having a BBQ about half way through the event, probably around 3:00 or 4:00. Ticket/Cost info below.
TO REGISTER FOR THIS EVENT
Please send payment via E-Mail Money Transfer to jammin1911 at gmail.com and be sure to provide us with the answer to your security question. If EMT payments are not an option for you, please contact John (jammin1911 at gmail.com or text/call 905-616-2299 anytime) to make arrangements to drop off cash. Arrangements can be made for cash drop off in Oakville, Vaughan or Campbellville.
Event Details
Location: Dunnville Autodrome (www.dunnvilleautodrome.com)
Date/Time: Sunday, May 17th 12:00PM to 6:00PM
Cost: $100 Pre-Pay, $110 at the track (Additional drivers: $25 each)
BBQ!!!: $5.00 gets you 3 tickets
Ice Cold Soda/Water = 1 Ticket
Hot Dog = 1 Ticket
Cheeseburger = 2 Tickets
Please remember, this is a GRIP ONLY event – no intentional sliding permitted during any of our events.
Mufflers are absolutely required for all vehicles on track.
Helmets are mandatory for all convertibles and highly recommended for all other vehicles.
We will be running in the clockwise configuration for most of the day. We *may* switch to counter-clockwise towards the end so that people can get a taste for some higher speed lapping. We will play this by ear based on your feedback!
If you have never been to a track day / open lapping event, or if you have been before and just need a refresher please keep reading for some tips to help make sure you are properly prepared. Otherwise, thanks and we hope to see you at the track!!
BE PREPARED!
Your Car:
- Inspect brake pads and rotors for wear and/or damage. OEM or equivalent brake pads will be eaten worn much quicker than normal under these extreme driving conditions
- Recommended to bleed your brakes – if you haven’t already, do a complete flush of the OEM fluid and with a good fluid with high boiling temperature. DIG recommends Motul RBF600
- Ensure all exterior lights are functional
- Check all fluid levels
- Ensure all suspension components are in good shape and torqued to spec
- Ensure all wheel lug nuts are torqued to spec
- Inspect tires, check for cracks, buldges and bubbles
- Inspect exhaust. Make sure it is firmly secured and that there are no leaks
- Please make sure there are no loose pieces on the outside of your car that may fall off on the track – this could be very dangerous for you or someone behind you
- Turbo cars make sure all of your couplers are tight and that you have no cracks/leaks in your system
- Alignment: If you haven’t had it done already – Call Sasha at www.SG-Motorsport.com and have him set your car up properly – a proper alignment will completely transform your car. No, Sasha is not associated with our events – we just love him and he has an incredible new alignment machine from the space age and he knows how to work magic with it.
You:
- We recommend that you arrive 30 minutes in advance in order to get maximum driving time on the track. You’ll need to register, get all of the loose odds and ends out of your vehicle, possibly change your wheels/tires to what you’ll be using on the track, etc.
- Bring extra cash. You hopefully won’t need it, but you never know what could happen under these unpredictable conditions. You might find yourself having to purchase something from someone (fluids, fuel.. who knows)
- Bring extra GAS! There is not 94 octane close to the track. There is however an Esso about 10 minutes away that has the usual 87/89/91 if you need it
- Fluids: Bring extra brake fluid, oil, coolant.
- Bring a friend! Spectators are always free and always welcome. More people means more fun for everyone
- CAA – If you don’t already have it, get it! They’ll tow you up to 4 times per year up to 200 kilometers per tow! For about $100/year you’ll never have to worry about paying $300 or $400 to get your car towed home.
- Spare tire(s), because you just never know
- Tools! Lots of people there will have tools but don’t bank on them – bring your own just in case
- Tire Pressure Tester, this is not only important to have with you always but very helpful in fine tuning your tire pressures at the track
- Folding chair. Trust us.
- Camera
That’s all for now. We hope to see you all out there this summer. Have fun and be safe!
Love,
The DIG Track Days Crew
      05-09-2009, 02:17 PM   #2
mazzawi
2005 Z4  [5.00]
I went to this last year, these guys make track events about once a month during the summer.
      05-09-2009, 07:29 PM   #3
F360C
Drives: E86 S54
I usually hit up the CSCS events but did one at dunnville last summer that was put together by a member of maxbimer. Dunnville is a fun track and hard on brakes. I think I am going to go and hit up a monday night of lapping at cayuga not this monday but the next
07 Z4 M Coupe AW/IR
