09-12-2015, 11:29 AM | #133 | |
Rep 541
The power delivery is as smooth as before and feels like a NA engine all the way. Top end power is an massive improvement over the original 3.0Si. The low end torque isn't that different, but it has always felt really strong on the low revs, I missed something at the top end. And with the supercharger it has becomed a perfect match.... I have not driven a Z4M before, but have driven a few E46 M3s. This feels way faster
[SIGPIC][/SIGPIC]
09-12-2015, 12:36 PM | #134 |
Rep 2,705
Very nice
Maybe consider a WMI system to keep the IAT's lower, it is really going to be tough to get cool intake air. Where is the MAF sensor (hot airfilm) located on the N52? Does this particular set up use a by pass or blow off valve??
09-12-2015, 12:37 PM | #135 |
Rep 12,565
The brakes look fantastic, I bet you could sell those brackets to a lot of folks seeing how the front brakes are same as e46 330i (and a lot of e36 and e46 upgrade to 330i brakes as well). The mod on the rear brakes is awesome.
09-13-2015, 01:57 PM | #136 | |
Rep 541
Yes, I will consider a water injection system. The MAF sensor is under the tube between supercharger snd airfilter. I really don't know what it uses |
09-13-2015, 01:58 PM | #137 |
Rep 541
09-15-2015, 09:11 AM | #140 |
Rep 5,329
looks so exotic.....
what a car, this has got to be one of bmws best designs for a long long time, the current direction for them is probably meaning this is going to be the last ///M car ill own tbh, bmw have dropped off the radar for me.
09-26-2015, 04:57 PM | #143 |
Rep 541
Done some new installs to the Z again
The rear H&R adjustable sway bar... I allreay have mounted the 27mm Z4M front sway bar. Poly bushing to the front and rear sway bars as well. The rear sway was adjusted to it's firmest setting, making it more oversteered for some drifts Also got me some new front control arms. They are Z4 M-sport for track use. Stiffer bushings and a little different angles. Don't know how much, but will do a new alignment soon. Then I can see if there are some changes to the stock ones |
10-21-2015, 01:55 PM | #145 |
Rep 541
10-21-2015, 01:56 PM | #146 |
Rep 541
Got me one of those clean multi displays for the Z
Very easy install and connected to the obd2 gate. Will also install some input from the supercharger, then it will show boost as well Right now it shows rpm, real speed, water temp, 0-60 time, throttle, intake temp, voltage and got a shift light.. |
10-21-2015, 02:03 PM | #147 | |
Rep 1,691
10-23-2015, 12:09 PM | #148 |
Rep 541
10-23-2015, 01:20 PM | #150 |
Rep 2,705
Got some good looking friends there
10-29-2015, 03:01 PM | #151 |
Rep 541
10-29-2015, 03:20 PM | #152 |
#dubspec
6339
Rep 5,201
haha awesome...that was exactly my idea! the housing all black make the projectors look really small. this looks excellent
10-29-2015, 03:21 PM | #153 |
#dubspec
6339
Rep 5,201
another idea i had was making the turn signal lens completely satin. almost like the eyebrow of the new bmw's
10-29-2015, 03:22 PM | #154 |
#dubspec
6339
Rep 5,201
question for you...are those TSW bathurst wheels?
