06-21-2016, 04:20 PM | #1 |
Rep 25
Issue with Homelink with ignition on.
Yes, I know I know this has been beat to death; and believe me my concern here is not what you might think it is. I've done quite a bit of searching, and can't quite find any posts that describe this particular problem.
By now I've memorized the set-up process...it's really quite simple. The issues I'm facing here are: 1. I'm unable to program anything while the car is actually on. Homelink lights turn on solid when pressed, and nothing happens even if I hold pressed....just solid on light. (No problem with key in Pos 1 or 2.) 2. After successfully programming with the key in Pos 2, garage door opens/closes just fine IF the car is off. However, if the engine is running, not so much. Hitting the homelink button with the car running yields a solid green light....no quick on/off to let you know it's working. Has anyone here encountered a similar issue? Is this a coding issue with the vehicle? FYI, garage door motor is rolling code, not linear...not sure that's relevant though. Thanks |
06-21-2016, 05:52 PM | #2 |
Rep 2,866
You have homelink in your Z???
06-22-2016, 01:31 AM | #4 |
Rep 2,866
HomeLink => http://www.homelink.com/home/welcome
06-22-2016, 04:47 AM | #5 |
Rep 25
Wasnt quite sure if responses were meant as sarcasm. Lol. Was HomeLink a rare option on MZ4's? If this was retrofitted by previous owner, perhaps it was not wired to the proper fuse?
In any case, I suppose. I should try calling HL support and see what they've got to say. |
06-22-2016, 09:39 AM | #8 | |
Rep 2,866
06-22-2016, 04:17 PM | #10 | |
Rep 305
That's odd - I just bought my '06 Z4C a few months ago - it's got a "clown nose" rear view mirror (big red bulb thingy on the bottom - not sure what it is) and it has the Homelink buttons along the bottom edge of the mirror. Works great on the my gate. Is that not the correct mirror?
2006 Z4 coupe - with HOMELINK!
1966 Mustang GT fastback (too many mods to list) 2015 335i GT 2014 981 Cayman S manual |
06-22-2016, 08:49 PM | #11 | |
Rep 2,866
06-23-2016, 06:16 AM | #12 |
Rep 305
HA! Should I list my ultimate cupholders too?
06-23-2016, 08:27 AM | #13 |
Rep 273
I retrofit a Homelink module to the panel under the climate control a couple of years back, and wired it to permanent power. The unit has nothing to do with coding in the car - it's an independent device. I have both a garage door opener and gate opener programmed, both work fine with the car on or off. They are both fixed code (not rolling code) devices.
06-23-2016, 09:20 AM | #14 |
Rep 2,866
