03-07-2012, 03:11 PM | #1 |
Rep 862
CAI hitting another part
After installing my CAI, I noticed a noise coming from the engine bay when I started it and stopped it. This only started happening until after I installed the CAI. After listening to it a few times, I think the lower left part may be hitting another part of the car in the alternator.
I tightened everything up, but it still wiggles and hits the part. I can adjust it so it is directly touching the alternator, and thus not making the noise, but I didn't think that would be wise. Any suggestions on how to cure this? Is this something that needs to be cured and could cause damage down the road? It doesn't wiggle that much, enough though to touch part of it during starting/stopping. Thoughts? |
03-07-2012, 03:52 PM | #2 |
Bad Lieutenant
232
Rep 3,517
Is this an M model? Possible the engine mounts have not been checked/inspected? If you suspect this CAI, put a piece of carbon paper attached between the two, and drive around, if you see the ink on the alternator, then you are correct, they are hitting.
03-07-2012, 04:21 PM | #3 |
Rep 862
Yes, it's an M. Well I'm 99% it hits. I can just push it down. I'm kind of surprised it doesn't fit better.
It only has 17,000 miles, and the old air box was just fine, so I don't think it's the engine mounts. Should I just bend it a little and let it be? It's not like it's hitting it constantly. |
03-07-2012, 05:54 PM | #4 | |
Rep 1,772
Drives: 2007 Z4M Coupe
03-07-2012, 06:03 PM | #5 |
Rep 862
AFE, sorry.
I went back out and adjusted to two right bolts where the clips used to be, pushed them in about 1/4 inch and that seemed to help. Anyone else have this problem? When I had my Z3M I installed a Conforti CAI and it fit absolutely beautifully. |
03-07-2012, 08:11 PM | #6 |
Rep 740
I never had this problem with my AFE, make sure it's seated correctly, I remember when I was installing it, it wanted to sit more to the passenger side than it was supposed to.
