      03-10-2020, 04:15 PM   #1
wdb
dances with roads
wdb's Avatar
4732
Z4MC new clutch and flywheel - what to get?
Stock horsepower, stock intake, Z4MC. I may someday do the CSL intake stuff but that would be it. I'm replacing the clutch and flywheel. I'm a lifelong manual gearbox user and honestly very gentle on drivetrains in general. I drive hard but I don't hoon.
What should I use to replace the clutch and flywheel?
LUK - has anyone gone with that brand? Pelican Parts and other sites tout it as "OEM quality" or somesuch, and the price is attractive.
OEM - I would do this in a heartbeat if all I was replacing was the clutch stuff. The OEM flywheel price gives me pause however.
Other DMF - I see some others out there such as Phoenix Friction, but I haven't found much in the way of customer ratings, particularly for DMF.
Something else I'm missing...?
"Stage 1" - I see no reason to do this and I really don't like what I read about solid flywheels on S54s. So I don't see myself going this way.
      03-10-2020, 07:44 PM   #2
vt100
vt100's Avatar
126
Drives: '06 Z4MC, '12 128i
I thought LuK was the OEM manufacturer for BMW's DMF.
      03-11-2020, 05:51 AM   #3
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Stock everything? Easy mate. Stick with OEM. No hassles.
      03-11-2020, 11:20 AM   #4
wdb
dances with roads
wdb's Avatar
4732
It sorta kinda gets pitched that way.
The more I think about it the more I think you are right. I still would like to hear more about the LUK brand though.
      03-11-2020, 08:44 PM   #5
wdb
dances with roads
wdb's Avatar
4732
I went with LUK. Pelican Parts assures me that it is the OEM for the bits I’m replacing.
      03-12-2020, 01:44 PM   #6
///Mcoupe
Drives: 2007 M Coupe
LUK makes the flywheel and sachs make the clutch.
wdb4732.00
      03-15-2020, 04:29 PM   #7
Sliktop
Drives: 07 Z4 M Coupe
Make sure you get the right part numbers though, I bought a set off one of the major vendors as a "Z4M package", had it installed, works OK, but loud af and has vibration issues at high RPM. Turns out, I got the wrong part numbers in the package. It was for Z3 version and had slightly different part number when compared to orig manufacturer website. Anyway.. be careful if you buy a package deal and check part numbers against the oe manufacturer.
wdb4732.00
      03-16-2020, 02:59 PM   #8
wdb
dances with roads
wdb's Avatar
4732
I'll soon know -- should be delivered today. I'll be sure to check the part numbers!
EDIT: They're here. According to my best ability to double check the numbers, these are correct. Fit M3 and Z4 "3.2L" applications. And I found out just how much I overpaid by not ordering through Rock Auto. :-/ If anyone needs a LUK clutch kit they're on sale there right now!
      03-16-2020, 11:45 PM   #9
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Which throwout bearing did you grab?
      03-17-2020, 12:31 AM   #10
wss4
Drives: 2008 Z4 M Coupe
I installed a LUK clutch kit recently and have a much lighter clutch pedal now. Seems that pressure plate springs may have changed. Interested to see if anyone else has experienced this.
wdb4732.00
      03-17-2020, 04:23 PM   #11
wdb
dances with roads
wdb's Avatar
4732
The LUK clutch is a kit. It contains clutch disc, pressure plate, t/o bearing, input shaft bearing, alignment tool, and grease for the splines. So I guess I got a LUK t/o bearing.
In my past experience with clutch replacement I always got a lighter pedal. That may just be an artifact of old vs. new. My problem was low engagement, too near the floor for my liking. I'm hoping that gets fixed!
Vanne1620.50
      03-17-2020, 09:04 PM   #12
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
fingers crossed mate let us know how you get on.
Powered by
      03-17-2020, 11:52 PM   #13
vt100
vt100's Avatar
126
I had very bad experience with Rock Auto few years back when they sold me faulty KYB shocks (that was for Toyota ) and refused to return money for that even after a lengthy talk with their "manager".
Before that I had lots of issues with various parts bought from RA but managed to return those. It really looked like chances to get a faulty / broken / used part was about 50:50. Since then I stay away from this shop even though their prices are tempting..
For my bimmers I usually go with (in order of preference) FCPEuro, or Tischer, or ECS.
wdb4732.00
      03-18-2020, 08:48 AM   #14
3798j
3798j's Avatar
11426
Drives: E86 3.0si
'55 Ford F100  [0.00]
'08 Z4 3.0SI  [8.50]
'66 Triumph TR4A  [0.00]
'85 Corvette  [0.00]
'64 Corvette  [0.00]
'68 Triumph GT6  [0.00]
'19 VW Golf "R ...  [0.00]
My experiences using RockAuto have always been positive. Even their rebuild/core return policies get executed/credited without issue. Over the years, buying for many different makes from many different countries, no problems. There's always a 5% discount code to be found with a search (the code gets placed in their "how did you hear about us" block). The only caveat is to pay attention that your parts aren't shipping from multiple warehouses...otherwise shipping costs can be high.
On another note...I have always had good results using LUK clutch kits.
wdb4732.00
      03-23-2020, 05:08 PM   #15
creativeliberty1776
Drives: 2003 bmw z4 3.0 6 speed
2003 BMW Z4  [0.00]
Any body have links to exact fit for 2003 BMW z4 3.0 clutch conversion kit 6 speed? I'm mechanical inclined.... but there are far to many choices out there and I don't want any issues the day i have access to the lift for this.
      03-23-2020, 07:27 PM   #16
3798j
3798j's Avatar
11426
Drives: E86 3.0si
'08 Z4 3.0SI  [8.50]
'85 Corvette  [0.00]
'64 Corvette  [0.00]
Take a look here by following the prompts...make, year, model, engine:
https://www.rockauto.com/
      03-23-2020, 08:28 PM   #17
wdb
dances with roads
wdb's Avatar
4732
I checked the bits I took off. Flywheel and pressure plate are stamped “LUK”. But...
...funny you should ask. The bearing that came with the LUK kit was faulty and Pelican Parts sent me another one. It was a Sachs. Identical to the original, unlike the LUK which had minor differences.
