      07-29-2014, 02:00 AM   #1
donoman
Rookie
31
Drives: 03 Z4 2.5i 5MT
What is this A-pillar part, and how can I fix it?
Sorry guys, I've looked on RealOEM for 30 minutes and cannot find this part. I have no idea what it does but it kinda sticks out and it's bothering me. I think it may be contributing to some wind noise I'm experiencing with the car. Thanks in advance for your help!!!
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      07-29-2014, 06:51 AM   #2
chickdr
Drives: 2006 M Roadster
I believe it is here: http://www.realoem.com/bmw/showparts...42&hg=51&fg=40 (part #5)
      07-29-2014, 04:46 PM   #3
donoman
Rookie
31
Thank you very much!! I wonder what it does? It's not sitting very nicely.
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      07-29-2014, 07:15 PM   #4
chickdr
I think it is there to create a seal for the front edge of the side glass. Otherwise wind would likely pull it away from the door at speed. I wonder if you could simply remove and reattach the one you have. Maybe it just got bumped at some point. I have no idea how it would be R&Red...
      07-29-2014, 08:47 PM   #5
omglukewtf
Drives: 2008 Z4 M Coupe / 2011 E93 M3
FYI: It's held on with tape and some push rivets.
      07-30-2014, 03:30 AM   #6
donoman
Rookie
31
I was able to tape it, but looks like the push rivet is gone. I guess I will just buy one, can anyone verify it's item #8 and looks like this:
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      07-30-2014, 11:26 AM   #7
omglukewtf
Looks like the correct part on the diagram, but on the coupe, they didn't look like that. They have a flat head so to fit under the rubber weatherstrip.
Looks like you should have 2 on each side, so just check the other side?
      07-30-2014, 02:04 PM   #8
donoman
Rookie
31
I looked on the other side... Looks like that side is sealed with some butyl glue or something. I went to the dealer and got #8. This rivet looks too big. It would help to know if I can just pull this rubber door molding back.
      07-30-2014, 02:16 PM   #9
donoman
Rookie
31
Ok I just pulled the moulding back. Just pull straight down. Unfortunately this rivet is way too big.
Here is the correct RealOEM link for my 2.5i: http://www.realoem.com/bmw/showparts...42&hg=51&fg=40
      07-30-2014, 05:28 PM   #10
omglukewtf
I don't want to give you wrong info, but FWIW the coupe uses 5 of these on each side to hold that trim piece in:
http://www.ecstuning.com/BMW-E53-X5-...dware/ES95322/
