      07-06-2016, 09:28 PM   #1
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Cutting Headligjht open? DIY?
Anyone have a good DIY with pics that shows you where to cut to remove the lens on our headlights?
Powered by
      07-07-2016, 07:42 AM   #2
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Vanne,
This one has a good description with some pics.
http://www.zpost.com/forums/showthread.php?t=724153
Salty
      07-07-2016, 09:59 AM   #3
tominizer
tominizer's Avatar
Drives: 2007 Z4M Roadster
I read through the above link and have a question.
With all the "other" cars I've owned, we have ALWAYS heated up the head light housing so soften up the adhesive and then just pulled the headlight cover off. I think only one person mentions it in the above link. Is the "heat" method not possible with Z4 headlights ?? It's a lot less destructive.
I'm thinking about it because I want the inner mirrored portion to be black.
      07-07-2016, 10:25 AM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
The adhesive used has a melting point very similar to the plastic, so you can imagine the result.
      07-08-2016, 01:14 PM   #5
tominizer
tominizer's Avatar
Last one I did was a 2008 Mini Cooper Clubman S. Opened up the headlight to paint them black. Same sort of plastic lens I would have thought. Mind you, I was using a heat gun and being fairly directional and specific as to where the heat was going.
But I do understand your point. It would be a mistake that you can't recover from.
      07-09-2016, 05:46 AM   #6
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Yeah, its a given that the e85/86 headlight cannot be heat gunned open, so anyone care to share where to dremel it open?
Powered by
      07-09-2016, 11:42 PM   #7
AmmarYasirA
Ammar
AmmarYasirA's Avatar
Drives: a lot
This wont be of much help, but isnt there cuts/excess glue to where they would have been connected? I would think there would be like a line where the two plastic pieces joined together.
2018 F150 Platinum - Black/Black - Leveled on 34's - DD
      07-11-2016, 08:10 AM   #8
Hammam
BMW Freak
Germany
53
Drives: Z4M Coupe + E36 & F11 Touring
Cut between the black plastik housing and the clear plastic!
Have done it a couple of times and works fine.
But please use the (original) diamond plate with your dremel. All others will crack
EDIT: melting the glue did not work. I tried it twice :-(
But I have to admit that I saw a guy opening a e85/e86 headlight with a heat gun (youtube video) once. Cannot find the source anymore :-(
      07-11-2016, 06:37 PM   #9
tominizer
tominizer's Avatar
Heat gun - pry and insert tool - heat gun - pry and insert another tool - heat gun - find more tools to pry and insert. That's how I did it on cars of past.
