      06-27-2012, 03:18 PM   #1
3002 tii
3002 tii's Avatar
2282
When Do You Change Spark Plugs?
Assuming stock motor, no FI... at how many miles do you guys typically throw in new spark plugs? Does it matter on driving style too (daily commuter, normal track usage, etc.)?
Follow for latest mods
      06-27-2012, 03:47 PM   #2
Karacticus
Karacticus's Avatar
Drives: 2007 Z4 3.0si Coupe
I changed mine just before I got to 60,000 miles, not necessarily becuase they needed it, but because I don't like having to remove plugs that have been in for 100,000 miles.
While there's some risk everytime you do any maintenance on the car, plugs are relatively cheap, and the jobs easy to do (given the correct tool), so why not.
Access to the plugs is also way more open in the Z4 than about anything else modern I've had the opportunity to work on. Certainly easier than on my wife's E90 328xi.
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters
      06-27-2012, 04:03 PM   #3
3002 tii
3002 tii's Avatar
2282
I agree, cheap (just bought these to pad my free shipping & discount order) but was contemplating on if I should replace these now or later down the road.
      06-27-2012, 04:20 PM   #4
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
I would say 60k miles depending on driving style. On the track with the higher engine temps, rpm, and fuel pumped through the engine, you probably want to change them sooner. I waited until over 90k to change mine, and that was too long.
Make sure you use a torque wrench and anti-seize.
      06-27-2012, 04:41 PM   #5
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
I usually change them yearly or around 20k, when i do a valve adjustment/check, I don't like to re-use the plugs as they have the crush washer (one time use?) and plugs are very cheap. I went with the NGK iridium as opposed to the OEM, gapped them, no grease or anti-seize after cleaning the wells.
      06-27-2012, 05:33 PM   #6
DreamTheater
Drives: E85 Z4
My Z4 is sitting at 83,000km I did my plugs at 80,000 but I'm not sure if it's the first or second change as I bought the car at 70,000ish.
I'll generally inspect the plugs, filters, belts etc every 2 months myself and replace when needed.
      06-27-2012, 07:35 PM   #7
Walkurie
Walkurie's Avatar
Drives: 06 M Roadster / 99 Jaguar XK8
I changed at 50,000 because that is when I did the valves and the vanos filter. Figured to do everything at once and avoid the work of pulling it apart twice. Call me lazy.
      06-27-2012, 07:52 PM   #8
fercho
fercho's Avatar
Drives: 2005 z4 2.5
i just replaced mine, my car is a 05 with 100k
2005 z4 2.5i/// Aero front bumper, m rear bumper,08 rear lights, custom quad exhaust, matte black front grill, OEM alarm, llumar security film,m wheels, HID lights, LED interior and trunk light,Ipod integration, stubby antenna,tein s-tech springsx
      06-28-2012, 12:04 PM   #9
Traveler218
Drives: Z4 3.0i Montego Blue Matalic
I have a 2007 3.0i and I just replaced mine at 32,000 miles. I drive mine pretty hard and was having a miss fire problem. I was about to change oil and filters anyway and figure plugs are pretty cheap.
      06-28-2012, 06:54 PM   #10
Stromtech
Stromtech's Avatar
Drives: 2004 Z4 3.0i 6-speed Sport
Replaced mine around 60K miles....the old ones did not look too bad at that point but it does start better and run smoother now. Or is that Figment talking.
      06-28-2012, 07:47 PM   #11
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Here's the plugs from 2 M's each with ~ 22,000 miles...
http://www.zpost.com/forums/showpost...1&postcount=47
2006 Z4MC - #LL93158
      06-29-2012, 03:32 PM   #12
rsutoratosu
Drives: Z4 3.0i
how are the iridium on this car ? I have them for my accord and tsx (factory oem). I was going to change mine to iridium but must have read somewhere that its not recommended
-Roranji
      06-29-2012, 03:39 PM   #13
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
They are fine, they gap easy (they are NOT pre-gapped), I found variances when I took them out of the box. NGK makes great plugs and they are fine to use in the S54.
