06-22-2012, 04:06 PM | #1 |
Rep 358
Clear coat pens
06-22-2012, 08:34 PM | #2 |
Rep 556
Drives: 2003 ESS TS1 Z4
Paint Pen lets you fill in scratches as easily as using a marker. Inside this easy-to-use, felt-tip pen is high-quality urethane clear coat. Just shake the pen and press down to start it flowing. Once the tip is soaked, "color in" the blemish as if you were using a crayon. PT # APP 000 On sale $15.95
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit. |
06-23-2012, 08:53 AM | #7 | |
Rep 69
06-23-2012, 08:57 AM | #8 |
Rep 358
BTW....I was referring to clear coat pens not paint pens. I have a few scratches in the clear that dont go throught the paint. Instead of leveling the clear around it with a polish/compound, I was wondering if I could just fill in the scratch with the clear pen
06-24-2012, 10:30 PM | #9 |
Rep 1,991
I have not heard good things about those pens. Kind of like clear finger nail polish and doesn't give a clean look when applied.
