06-16-2012, 10:47 PM | #1 |
Rep 52
Seat falling apart
Help, when I got in my coupe today I heard a noise behind me. The backing to my driverseat had just fallen off!! It is not under warranty anymore and it shouldn't be a difficult fix even for a mechanically impaired woman such as I. Any suggestions?
06-17-2012, 01:15 PM | #2 | |
Rep 1,772
Drives: 2007 Z4M Coupe
06-17-2012, 02:40 PM | #3 |
Rep 2,782
Pics?
There are some tabs on the seat backs that can work their way loose.
06-17-2012, 03:57 PM | #4 |
Rep 52
Is this the tab? I found two of them hanging around loose in the seat, back side of them looks like some chipboard/cardboard had been once attached? How do I re-attach them?
06-18-2012, 08:48 PM | #5 |
Rep 10
yes, those are the tabs for the top. You should be able to glue those back on to the fiber-board seat back.. At the bottom of the seat back are 2 plastic plugs that go into holes in the seat frame. Those plugs are the things that keep falling out on my seat, with the result that the fiber board is getting kind of bent up at the bottom.. going to have to see if I can McGyver some kind of fix.
06-18-2012, 10:11 PM | #6 |
Rep 52
yes I saw two white clips on each side toward the bottom, and I can make out where the two top black one were attached but don't know the direction to to reattach them plus what kind of glue to use.
06-19-2012, 11:57 AM | #8 |
40
Rep 1,481
I was going to say an Epoxy adhesive from your local hardware store. You'll need to perfectly strip/clean the two bonding surfaces firstly. You could use Duct tape to hold them in position until cured. Some heat from the sun or a hairdryer will aid the cure time to be faster.
06-29-2012, 03:45 PM | #9 |
Rep 52
Fixed!!! I didn't have to remove seat, I soaked tabs in degreaser, and used dremel to grind off glued on fiberboard--also used it to cleaned out small grooves. Used utility knife to score fiberboard backing, used black marker to outline faint previous indentations for exact placement. Checked JB weld website--not so good for plastics. So I took tabs to hardware store and guy suggested liquid nails. Used duct tape to hold still cured. Had to manipulate backing around till everything snapped into place. Hope it holds.
06-29-2012, 04:18 PM | #10 |
701
Liquid nails. I've had good results with that with various applications.
If it doesn't hold, I wonder if some RTV type product or E6000 would work. Jack Russell I see? |
