      08-04-2014, 05:40 AM   #1
SwissArmy
Why so serious?
SwissArmy's Avatar
URGENT! Alternator connection question!
Hey guys,
I've recently got my alternator replaced. But, now I am plagued with low voltage codes on all my sensors. And, the car is in limp mode. I disconnected the top connector and noticed that there is only one "contact" visible in the connector. The alternator regulator has two males, whereas the connector has two females but only one has the contact visible. Is this normal? I would need to know this ASAP.
Alternator Regulator
Connector
Are there meant to be two of these? I can only see one of these contact wires coming through the connector
PART # 12520007171
Thank you
      08-04-2014, 06:38 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
The WDS shows only one wire from the alternator to the DME.
      08-05-2014, 04:38 AM   #3
SwissArmy
Why so serious?
SwissArmy's Avatar
Thanks StickMon
      08-05-2014, 04:39 AM   #4
SwissArmy
Why so serious?
SwissArmy's Avatar
Kindly check out my other thread, I need some help
http://www.zpost.com/forums/showthread.php?t=1018901
