07-19-2014, 05:59 PM | #1 |
Rep 9
Diagnostic Cable Information
Good day gentlemen,
I have a fairly specific question that I wasn't able to answer by searching threads. I want to buy a diagnostic cable for my car, but I'm a little worried about the date of production disclaimer on most of the cables I'm seeing. They mention that cars produced after March 2007 may not be compatible. My 2007 M roadster has a production date of August 2007, when I look it up on RealOEM.com. Does anyone know for sure that the standard/common BMW cable that you see every where, such as... http://www.ebay.com/itm/BMW-USB-OBD-..._Tools&vxp=mtr ...will work with my car, since it's post March 2007? Also, I've also noticed cables on eBay that mention they are compatible with: 1) Fast magistral D-CAN and PT-CAN (500 kbit/s) 2) Slow magistral K-CAN (100 kbit/s) Which apparently makes it compatible with later models because of the fast D-CAN standard. I have no clue, or way of being sure. Can anyone shed some light on this? Thank you very much. |
07-20-2014, 12:14 AM | #2 |
636
Rep 3,124
This has come up before, and you're right, to my knowledge it hasn't been answered.
I did some research on the 3-series forum, and "some say" you should get the K+DCAN. I think this (or similar) has you covered either way. It's pricier than non-canbus. There are some listed cheaper, but it looks like they only come with INPA. You want to make sure you get DIS and SSS (Progman), and probably NCS.
07-20-2014, 12:47 PM | #4 |
Rookie
32
Rep 379
I wrote a post about recoding the sound system from E86 (coupe) to E85 (roadster) values. In there, I remember suggesting where you can get the s/w.
2003 Z4 2.5i
2013 FR-S 1990 911 C2 1983 Wife |
07-20-2014, 12:49 PM | #5 |
Rookie
32
Rep 379
Oops, I just checked that post and didn't elaborate how to get the files other than to search Google. http://www.zpost.com/forums/showthread.php?t=982412
I suggest not installing the file on your primary computer without a virtualized installation ... these things can be riddled with viruses.
2003 Z4 2.5i
07-22-2014, 11:48 PM | #8 |
636
Rep 3,124
Only if you try to flash the DME. I think that program is called WinFPK. I stay away from it.
INPA and DIS are perfectly safe and great for diagnostics. SSS/Progman is safe and good for setting simple things that the dealer would charge you up the butt for. NCS is a bit of a faff, and I imagine you could screw something up, but I've never heard of anybody reporting that they did. I haven't tried NCS yet, but I might when my halo LEDs arrive. Haven't decided if I want to fart with it or just stick some resistors across them. Have many resistors.
07-23-2014, 07:59 AM | #9 |
Rep 9
Well my first and most important order of business will be to disable the seat belt chime. I also imagine that I'll probably need this to reset the oil change indicator.
So it sounds like I won't be harming anything by fooling with those settings. I'm glad to hear that flashing the DME is not required for these procedures. |
07-23-2014, 08:45 AM | #10 | |
Rep 1,107
07-23-2014, 07:21 PM | #11 |
Rep 9
Thanks.
I figured there had to be some other way to reset the indicator without hooking up a diagnostic tool...every other car on the planet can do it. I just read through that thread...they were talking about 15,000 miles between oil changes...what!?...that's forever. |
07-24-2014, 12:13 AM | #12 |
636
Rep 3,124
Pretty much everybody changes it at the 1/2 way point.
Every 7500 miles, unless it's a garage queen, then once per year. But only reset the indicator when it goes negative. And it's good insurance for the ///M to send a sample to Blackstone Labs for an analysis, and watch for high lead, indicating rod bearing wear.
