      07-07-2014, 10:55 AM   #1
sl03
Drives: 2003 BMW Z4 2.5i
Looking for a header
Anyone know of a good brand header I can buy for a 03 2.5i E85?
      07-07-2014, 01:59 PM   #2
Steeler
Steeler's Avatar
2429
I have a Bimmerbrakes header on my car (3.0) but you will get a CEL.
There are work arounds out there to eliminate the CEL but I have not heard if any work.
      07-07-2014, 02:07 PM   #3
sl03
I heard the E46 header from bimmerbrakes can fit the Z4, you know anything about that?
      07-07-2014, 04:23 PM   #4
Steeler
Steeler's Avatar
2429
That's what I was referring to
It fits perfectly
Get it coated first it really reduces under hood heat.
      07-07-2014, 04:26 PM   #5
sl03
It fits perfectly
Is the 3.0 a M54 motor?
      07-07-2014, 04:36 PM   #6
Steeler
Steeler's Avatar
2429
Yep
European power values but M54 came in 3 displacements
Engine Displacement Power Torque Redline Year Stroke Bore Compression
M54B22 2,171 cc (132 cu in) 125 kW (168 hp) @ 6100 rpm 210 N·m (155 lb·ft) @ 3500 6500 2000 72.0 mm (2.83 in) 80 mm (3.1 in) 10.8:1
M54B25 2,494 cc (152 cu in) 135 kW (181 hp) @ 6000 rpm 237 N·m (175 lb·ft) @ 3500 6500 2000 75.0 mm (2.95 in) 84 mm (3.3 in) 10.5:1
M54B30 2,979 cc (182 cu in) 170 kW (228 hp) @ 5900 rpm 300 N·m (221 lb·ft) @ 3500 6500 2000 89.6 mm (3.53 in) 84 mm (3.3 in) 10.2:1
S54B32 3,246 cc (198 cu in) 256 kW (343 hp) @ 7900 rpm 365 N·m (269 lb·ft) @ 4900 8000 2001 91.0 mm (3.58 in) 87 mm (3.4 in) 11.5:1
      07-07-2014, 04:39 PM   #7
sl03
Yep
I guess it should fit just fine on my 2.5 also then
      07-08-2014, 11:30 AM   #8
sl03
Yep
M54B22 2,171 cc (132 cu in) 125 kW (168 hp) @ 6100 rpm 210 Nm (155 lbft) @ 3500 6500 2000 72.0 mm (2.83 in) 80 mm (3.1 in) 10.8:1
M54B25 2,494 cc (152 cu in) 135 kW (181 hp) @ 6000 rpm 237 Nm (175 lbft) @ 3500 6500 2000 75.0 mm (2.95 in) 84 mm (3.3 in) 10.5:1
M54B30 2,979 cc (182 cu in) 170 kW (228 hp) @ 5900 rpm 300 Nm (221 lbft) @ 3500 6500 2000 89.6 mm (3.53 in) 84 mm (3.3 in) 10.2:1
S54B32 3,246 cc (198 cu in) 256 kW (343 hp) @ 7900 rpm 365 Nm (269 lbft) @ 4900 8000 2001 91.0 mm (3.58 in) 87 mm (3.4 in) 11.5:1
Did you get the GEN3 M54B25/B30 performance headers for $276 or the SS M54B25/B30 V1 performance headers?
      07-08-2014, 03:38 PM   #9
Steeler
Steeler's Avatar
2429
Gen 3
After talking to them the only difference was that they had relocated the O2 bungs to a "better" location for ease of sensor install in the performance header........I had no problem with the sensors.
      07-08-2014, 03:40 PM   #10
sl03
Gen 3
It's pretty cheap I'll have to order it soon, thank you for your help
      07-08-2014, 04:57 PM   #11
sl03
Gen 3
Sorry I misread that, so gen 3 and the SS are both supposed to fit the 2.5 M54?
