      10-27-2014, 09:39 AM   #1
wss4
Drives: 2008 Z4 M Coupe
Z4M and 3.0si transmission differences
I am trying to understand what exactly are the differences between the z4m and 3.0si transmissions. My second gear synchro is getting tired, and I have found a very low mileage transmission from a 3.0si. Will this work in a z4m?
From another thread:
The Z4M uses the GS6-37BZ-TJEE (BMW part number 23007837983)
The 3.0si Z4 uses the GS6-37BZ-TJES (BMW part number 23007565178)
Does anyone know the significance or the last 4 characters?
      10-28-2014, 06:10 PM   #2
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
I thought they were the exact same?
      10-28-2014, 11:46 PM   #3
tikamak
Lebanon
58
I know for sure that the M transmission has the pivot bearing in the crankshaft, checking on realoem 3.0si seems to have the same thing.
I think that the Z4M transmission have different internals, same ratio though.
You shoud ask http://wanganstyle.com/
He seems to know his stuff and rebuilds transmissions regularly.
      10-29-2014, 09:31 AM   #4
Incompatible
Drives: 07 AW Z4C 3.0Si
Over the years following various threads on lubrication, transmission mounts, shift problems..... for our Z4s, I can't remember anyone ever mentioning that there were trans differences between the M and Si cars.
