05-01-2016, 09:49 AM | #1 |
Rep 12
Headlight Out...Xenon
I have a question. When driving home last night I got a headlight warning light. Passenger side outboard low beam Xenon was out. What was weird was that the inboard light was glowing. Is this a controller or bulb or both?
2007 BMW Z4 3.0i |
05-01-2016, 10:40 AM | #2 |
Rep 187
Inboard light glowing? There are only two real projector housings on a facelifted e85 like yours. The inner lamps are fakes, but the halo rings should glow only on the two inner housings. If you have a xenon bulb out you'll just need to replace both. Yes, both sides. Grab a pair and toss them in, you should be good to go.
05-01-2016, 01:56 PM | #4 |
Rep 187
The bulbs will be expensive! Try to resist the urge to buy just one, they will end up being wildly different colours and you'll hate the look. Xenons slowly turn a purple hue as they age. It's not that noticeable if you drive the car every day but the comparison of a side by side old vs new will be strikingly different.
05-02-2016, 02:00 PM | #5 |
KPop
148
Rep 235
I got these OEM HID bulbs from Amazon and got 2-day Prime shipping for $85.
The OEM ballasts are pretty cheap too at $62 per side. Overall, the cost to replace bulbs and ballasts isn't bad at all. I'd also recommend doing the work yourself. It's pretty straightforward and you can go through the front wheel-wells. It took me about 30 min on the passenger side and then 10 min on the driver's side. Just wear latex gloves when handling the bulbs and try not to touch the glass bulb when installing or removing from the housing. |
05-03-2016, 02:41 PM | #8 |
Rep 1,351
Drives: in Anger.
Or do what I do when this happens and turn the lights on and off till they behave.
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs 1217/1815 !!! BOILER UP !!! |
wdb4732.00 |
05-07-2016, 10:30 AM | #9 |
Rep 75
05-07-2016, 05:19 PM | #10 | |
Rep 2,547
05-08-2016, 07:27 AM | #11 |
Rep 12
Light started working again the next day. Went ahead and replaced both bulbs and the ballast on the passenger side. The passenger bulb looked kind of burnt when taken out. Replaced ballast as cheap insurance.
05-08-2016, 10:43 AM | #12 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
I have actually had very good luck with the Xenon bulbs from Khoalty. They are $25 for the pair... yes $25 and they have worked well. After 2 years they started to colorshift slightly so I just picked up a new pair even though they were both still working.
E86 ///M Coupe - Imola Red/Imola Red
E60 ///M5 - (6 Speed) Silverstone Metallic/Black F06 640iX - Tanzanite Blue/Amaro Brown K66 ///M1000RR - Competition |
05-09-2016, 09:49 AM | #13 |
Rep 779
yeah.. the review says DO NOT BUYYYYYYY!
-Roranji
05-09-2016, 11:39 AM | #14 |
KPop
148
Rep 235
I think some may have been replicas, but mine were legit Phillips OEM bulbs (dealer confirmed for me before I installed).
Here's another link for the same bulbs w/ better reviews (a bit more expensive, but still less than at a dealer): http://www.amazon.com/Philips-Xenon-...9TWBNE99VB4YMX |
05-09-2016, 07:08 PM | #15 | |
Rep 2,547
They do a great job at duplicating the appearance. Your dealer may not know what to look for to determine if they are fake or not since it's hard to tell the difference. The printing on them is a tell tail sign. It's not like they don't work, they're just not the same quality. Plenty of people are happy with them and saved allot of money. |
05-09-2016, 07:28 PM | #16 |
KPop
148
Rep 235
We compared my bulbs with a 100% legit one they had in stock and they looked identical up-close. If they're fake, they're pretty good (great light quality, very bright, cheap, etc.), so doesn't bother me too much.
Here's a post that shows some comparisons between real and fake. This example is a particularly bad fake bulb. http://honda-tech.com/lighting-107/c...-pics-3004545/ |
05-18-2018, 08:48 AM | #17 |
Rocket Scientist
Rep 72
Drives: '08 M Roadster
I know this is a two year-old thread but I wanted to update folks that Tire Rack has the Philips D2S bulb for $52 with free shipping. Tire Rack is an authorized Philips retailer so I'm hoping the chances of getting a counterfeit part are low to zero.
russ
2008 ///M Roadster
05-18-2018, 12:04 PM | #19 |
Rep 326
The Retrofit Source has the Phillips D2S (85122) bulb set for $85, free shipping if you hit 100
the stable:
2003 BMW Z4 3.0i 2020 Mitsubishi Outlander SE 2021 Jeep Gladiator Rubicon |
04-01-2019, 12:46 PM | #21 |
Rep 195
OK forum pals. I have a headlight out and want some advice before I buy parts. A week ago, I noticed that my right side headlight had a dim purplish hue. Then a couple of days later, my dashboard lighting indicator came on. At that point I noticed the headlight was out completely.
The inner halo glows, but neither the high beam nor the low beam works. The left side light is fine. Do I need a new bulb or a ballast, or both? If I need a bulb, I will replace both sides at once. If I need to replace the ballast, do I also need to do both sides at once? Thanks in advance if anyone can help! This is on a 2007 Z4M Coupe, so it's Xenon. Last edited by DanFromTucson; 04-01-2019 at 12:47 PM.. Reason: Adding more detail. |
04-01-2019, 03:25 PM | #22 |
636
Rep 3,124
Purple, or could you call it pink?
Pink-eye is the standard failure mode for the bulbs. If you replace the bulb, you should do both so they're the same color temp.
Tags |
headlight, xenon |
