      09-16-2012, 07:53 AM   #727
flipm3
E46 + E90 + F80
192
Drives: E46 + E90 + F80
2009 BMW M3  [0.00]
2002 BMW M3  [0.00]
Originally Posted by Roffle Waffle View Post
could you ask your friend how much they charged for the tune?
I'll definitely ask him this week.
In the mean time, try contacting forum sponsor Imran@Evolve or Sal@Evolve
imran[at]evolveautomotive[dot]com
salman[at]evolveautomotive[dot]com
Originally Posted by Beedub View Post
now this is interesting :-) tom this totally changes the ball game for you imo.... you can now have vt- whatever you want..... obviously with hardware work!
i need to register on that forum and say hello.... ive never seen so many s/c installation questions, mods and general home building of addition power ect ect... very cool section! i have found a new home!!
Tom has really opened up some doors for the community, that's for sure!
With a lot of friends getting different brand superchargers, I am getting more and more tempted to turn to the dark side. It's just so hard to let go of my sexy CF Airbox
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread
E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread
      09-16-2012, 08:26 AM   #728
Beedub
i went over and made a thread on the FI section... pop in and say hi.
      09-16-2012, 08:29 AM   #729
flipm3
E46 + E90 + F80
192
2009 BMW M3  [0.00]
2002 BMW M3  [0.00]
Haha, nice! I'll do so now!
      09-16-2012, 10:47 AM   #730
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
thanks guys
      09-19-2012, 10:15 PM   #731
ZStig
279
FINALLY got a replacement controller/brain box for the AEM meth/water injection and installed it. I still have to correct the low fluid sensor position and run a power wire to my interior since I'll be installing a hidden power switch. Last time the system was on the whole time, and I went through the meth/water in 2 days. This time I won't use it on busy roads and in traffic.
So. I tested it. Ambient temperature was about 85*F, but once it kicked in, there was a noticeable boost in power that came on very smoothly and really made the top end much stronger. Definitely felt like 20-30rwhp boost.
Its set to progressively turn on at 2psi and run to 8psi. So it turns on around 3500rpm.
Very very happy I got it working again. When I had it working originally I didn't get the full effect because I was testing it in temps under 60*F. Now I feel it and it feels great. Now its time to schedule a dyno session in a few weeks
      09-20-2012, 10:35 AM   #732
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
What are your settings (nozzle size, mix, etc.)? Here's the info that I've come across...
Take your combined fuel injector cc and use a total meth injection nozzle as follows:
10% for 100% water
15% for 50/50 meth/water
20% for 100% meth
So for a 50/50 mix; use a 150cc nozzle with 1000cc fuel injectors.
      09-20-2012, 11:05 AM   #733
ZStig
279
10% for 100% water
20% for 100% meth
I just used the proven and established settings. Smallest nozzle, start spraying at 2psi and stop at 6psi or 8psi. The lowest my kit can stop at is 8psi so I went with that. 50/50 mix of course, can't use anything much stronger with the AEM kit
      09-20-2012, 01:32 PM   #734
Rated M Roadster
160
Which is? Are you able to see the difference on your AFR gauge?
      09-20-2012, 02:34 PM   #735
Beedub
heres how us ESS guys run this setup...
place the smallest knozzle as further away as possible from the intake mani AFTER the intercooler, on the 500 kits we use the smallest knozzle... using a 50/50 mix due to our pretty long boost pipework, we get the effects of a superchily AIT and minimal AFR changes.... if installed correctly you'll barely notice a difference on the AFR gauge.... i see 11.4 @ WOT on meth were talking 11.2ish.... its literally like running the car on one of those supercool winters days ..... its a really nice setup and works really well...
As you know mounted directly to the intake and spray direct port would mean were using it as a fuel ( would need a specific tune).... which is the complete opposite of what we want in this situation... All we want is the cooling effect on the AIT and as a nice bonus the cleaning effect of the steam created as it all atomises....
because of where ESS mounted the AIT sensor... the car is basically fooled into thinking its super cold and does all the changes for us.... when it runs out... it simply thinks hmmmm its warm again... back to the other settings... no failsafes needed as the ess tune dials everythink back....
after driving this car on a sunny winters day last year -6 it was that day.... the power difference was incredible.. i dont use that word lightly.... so meth is a really nice little bonus for us.
we see an easy 35-45rwhp on hot days using the setup as above. The effects are even better on the 550 kit.... which il b ordering next week!!! wahooooo..
      09-20-2012, 03:00 PM   #736
ZStig
279
yeah I don't have an AFR gauge, but I'll have some hard dyno numbers soon, and some hard before/after quartermile track numbers too
the new controller SEEMS to be using a lot less meth/water than the old one too, so it might even be cheap enough for me to keep this thing on most of the time. I might even dial it to kick in at 3psi, which would further decrease its use and cost of consumables
Right now I'm using a 49/51 pre-mixed "Boost Juice" which runs $9/gallon. I've been tipped off about a place where I can buy pure methanol, and mix it myself to save money.
Beedub, I'm jealous about your upgrade! super jealous. Make sure to make a detailed thread comparing the replacement parts
      09-20-2012, 03:27 PM   #737
Rated M Roadster
160
Do you know what cc injectors the ESS kit has and what cc nozzle the AEM kit has (google is showing me 150cc for the small nozzle)? If 150cc, then the combined fuel injectors should be 1000cc (should be twice or more than that)... Not saying you guy haven't already found the ideal setup; I'm just trying to confirm what you guys are running with my research, which is you guys could run a larger nozzle (if you are indeed running a 150cc) and get even better results.
I've been researching running a non-tune dependant meth system just for cooling and putting 6 injectors in the manifold like so (but not so tacky as in this pic):
      09-20-2012, 03:35 PM   #738
Beedub
hi tom.... hope all is well bro...
yeah good idea.... you could be use de-ionized water as the mixing agent with the meth, this should be readily available and much cheaper than the boost juice...
thanks bro.... ill b ordering the kit next week for my birthday.... like i have done for the last 2 years on each upgrade consecutively.. all i pray is its a reliable and runs like the vt-500 which imo.... is a fabulous kit.... BUT... i want the Tq the 550 kit offers.... that 2 psi nudges the blowers right into its efficiency range and starts... when i arrives ill give you some detailed specs on the intercooler/parts ect... which BTW is the same size just .5" deeper. at this point the 550 upgrade is minor now in terms of parts.... With meth in place im hoping to finally break the 500rwhp. i always wanted.....
Once ive pressed the button ill make a thread.... Very very excited!! 80mm pulley sooooonnnn!!! While im getting the 550 tune done i'll get Ess to activate the shift lights. This months salary see's the final bit of change i need :-)
      09-20-2012, 03:37 PM   #739
Beedub
130cc is the knozzle we use .... the 150 bogs the car and looses power..... im guessing on the 550 the 130 may not make much difference and the 150cc will be the one i want.
      09-20-2012, 03:40 PM   #740
Beedub
rate m... only problem is see which spraying right their is no time for the mix to atomise.... which would lead to it being used a fuel... therefore needing a tune to run it. I guess VF would be able to chime in more on that. Its one of the things of love about air/air.... piss easy meth plumbing.....
i love the setup on the direct port meth.... if i had the balls to run a proper meth tune the gains are big.
      09-20-2012, 04:56 PM   #741
ZStig
279
I'm going page by page on that german ************ website and collecting as much data as I can. I read the whole thread about that individual cylinder meth job. The only reason he did it is because the VF kit uses a air/water cooler that is set up inside the intake manifold. So for him to spray where we spray, it would technically be spraying into a radiator type setup, and wouldn't come out as clean and atomized as going on our single kits. He said if he had an air-air intercooler, he would have gone the single nozzle route. The way I see it, the simpler the better
Thanks for the data on the intercooler upgrade size! There is actual a special math formula to figure out the size of the intercooler u need, but I don't have the time to dig it up. When I upgrade mine, I'll just get one that would be able to support 600rwhp to future-proof myself
      09-20-2012, 11:27 PM   #742
ZStig
279
kinda hard to shift perfectly when TC is off, and you're holding the camera in the same hand thats holding the steering wheel correcting wheelspin
First short clip is rolling onto the throttle in 1st gear, letting off near top of 3rd. Second part is flooring the throttle in middle of 2nd gear to demonstrate throttle response.
Traction is pretty good in 80*F heat =)
Going by the video as a rough estimate, this matches or beats my previous 50-70 acceleration of 2.0 seconds which was done in the dead of winter
      09-21-2012, 02:11 PM   #743
Beedub
hi tom i see why on the VF setups.... thats the only Air'd part of the setup to use a wrong term.... however.... your thoughts on the spraying into the cooling bit made me smile!!! re read it and you can see why i smiled :-) on the VF setup how about using a cryo system to cool the water radiator?? as its the water the cools the air.... this may help a little....
and you are 100% correct.. simpler the better....
      09-23-2012, 10:17 AM   #744
ZStig
279
This morning i had a rough initial idle with some burps and white smoke out of the tail pipes. In a minute the idle settled down. I drove 10 feet, the rpms dropped and the car wouldn't restart. Now it doesnt even crank. Its possibly hydrolocked or the headgasket blew. Headgasket looks ok on the perimeter. Will check what i can with my limited tools today, then tow it to a local shop (((
      09-23-2012, 10:44 AM   #745
Beedub
oh fuck....... im scared right now.
ok can you share some more details?? kinda strange that your meth is fixed and all of a sudden this has happened??? i dont suppose its dumped a load of water/meth into the motor for any reason.... ??
not often we see the HG fail on these and we have plenty of high mileage units WITH boost still running....
Have you had lots of rain or run a huge puddle?? (wondering why you think its hydro-locked?)
anymore details on the variables would be great??? Whats your mileage now??
      09-23-2012, 12:08 PM   #746
Beedub
if worst comes to worst and the head gaskets done..... i'd use this time to rebuild the motor top to bottom.... can you afford that right now or out of the question??
      09-23-2012, 01:16 PM   #747
ZStig
279
I had very little meth left in the tank the night last night, but I guess its a possibility it was all leaked into the pipes overnight, and then dumped into the engine this morning. I'm gonna take apart my boost pipe and see if any of it pooled.
I checked the oil dipstick, and thankfully didn't see any water. I'm gonna disconnect my meth kit fully, and check the wiring to make sure the ignition wire its sharing is OK.
Thankfully this didn't happen while I was hammering on the car, it just happened after the car sat overnight in the rain. Maybe it gulped up some moisture somewhere. I have no idea, just gonna do a quick meth kit check and then try to start the car again...
If it doesn't start, I won't take anything apart, and just tow it to a shop tomorrow. Unfortunately I'm new in town, so I'll have to do some reasearch of local specialists.
I really hope its nothing serious, I guess I could rebuild whatever it needs, but it would be on borrowed money
      09-23-2012, 01:26 PM   #748
Beedub
i dunno why tom...but im really leaning towards the meth mixture leaking into the boost pipe.... i wonder if that would cause any damage taking that in, in large amounts?? it just seems strange that youve got the meth fixed then ?????????
