11-14-2016, 01:50 PM | #1 |
Rep 195
Rear wheels spinning in neutral?
I had my baby up on jackstands with the wheels off. With the engine idling in neutral the rear hubs were spinning slowly. Easy to stop just by holding the hub by hand, but I've never noticed this before. Of course, I rarely run the engine while the car is in the air. Is this normal? An indication of clutch wear? Should I be worried?
11-14-2016, 05:06 PM | #2 |
Rep 2,544
Since all the gears in the trans are spinning, yes the the wheels can turn from oil drag on the output shaft of the trans. I've seen it with other cars, though I never tried it on my Z4.
11-14-2016, 05:12 PM | #3 |
1821
Rep 5,337
Normal. All manuals will do this.
If my understanding of manual transmissions is correct, while in neutral the driveshaft is disconnected to the input shaft, but the entire clutch/pressure plate assembly is spinning freely while immersed in transmission fluid. That motion influences the output shaft and cause it to spin despite the two shafts not physically being connected. While on the ground that motion is easily overcome by the friction of the tires vs. surface. When up in the air, enough energy gets transferred over to cause free hanging wheels to spin. EDIT: What Pungo said.
11-16-2016, 12:28 PM | #5 |
Rep 166
11-20-2016, 11:14 AM | #6 |
Rep 753
Agreed on theory, but our clutches are dry and sit outside the "transmission" so to speak. And, I have observed the same on my car when on stands.
