      11-17-2016, 04:43 PM   #1
prototype55
Drives: n/a
Couple of questions
Hi,
I am thinking of getting a z4 m. my first question is how many miles on a z4 before it becomes problematic, i see a lot of z4m's with 70-90k miles and i am a bit nervous about buying a performance car with that many miles. Second question is coupe or convertible? I plan to use it as a daily driver and maybe do autocross or track day very occasionally. I have just started getting into the z4 m and I hope to own one after I learn a bit more about them.
Thanks guys
      11-17-2016, 06:00 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
I have nearly 150k miles on mine. Leaks oil like mad, but runs great.
Buying a high mileage one will depend on what maintenance was done by the previous owner.
Do a search in these forums for Vanos to get an education on some of the more expensive things you'll want to make sure have been done.
As for coupe or roadster, it depends on what the weather's like in n/a.
I love having the roadster here in SoCal. Chilly today, though. Only 75°.
      11-17-2016, 06:26 PM   #3
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Wow - you hit 150k already? I have about 100k to catch up. Well...more driving fun to do
Chilly day indeed - I had to break out the jacket even in my coupe
Don't forget about the other expensive item - rod bearings
      11-17-2016, 07:16 PM   #4
prototype55
Drives: n/a
Thanks for the response guys. I live in NJ so it can get below 0 F in the winter and summers can get up to 95ish F. How well does the heater in the convertible work, and how well does the top keep the heat in?
      11-17-2016, 08:15 PM   #5
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
You know that we're just busting your chops about being chilly in SoCal 75* weather, right? The heater works fine in these cars, but my suggestion is to look for one with heated seats if you want a convertible
deemo3191751.00
      11-17-2016, 09:52 PM   #6
prototype55
Drives: n/a
Thought so but i just wanted to be sure. I know convertibles can leak heat out really fast so i was just curious if the same issue happens in the z4
      11-18-2016, 06:43 AM   #7
Huz-Z
Huz-Z's Avatar
I saw one review a while back compare the Z4 heater to a small nuclear reactor approaching meltdown - you should not be cold. If the heated seats in the Z4 are anything like the ones in my wife's 328, you may find that you have to turn them down - they are that good.
Huz-Z
      11-18-2016, 09:09 AM   #8
KPop
KPop
KPop's Avatar
No_Country
148
Drives: Horse and Buggy
Originally Posted by prototype55 View Post
Hi,
Thanks guys
There are a lot of variables at play, so it's a bit hard to pin down a specific mileage range to watch out for. Proper maintenance and care is usually the biggest factor on reliability. Did the prior owner follow the recommended maintenance schedule and not abuse the car or were they doing redline clutch-drops on a cold engine? You need to find an enthusiast owner who has documented maintenance history.
Overall, I feel the Z4M's are pretty durable and the engines, aside from a few hit-or-miss issues (rod bearings on early model years, VANOS, engine mounts) are especially durable and overbuilt. My Z4M only has 35k miles, but I've had zero issues.
The coupe is better suited for track and autocross thanks to a stiffer frame and body. It's actually a little heavier than the roadster, but it's hardly noticeable. I've never tracked or raced my roadster, but I'm sure it would still be a lot of fun on a track.
      11-18-2016, 09:35 AM   #9
RedOctober
RedOctober's Avatar
Ukraine
33
Drives: '13 M3
Are you looking for a year round daily driver ? Convertible so you can drop the top on those few nice NJ days.
Serious about track days more than once in the car's life?
As mentioned already, coupe is the way to go. Significantly stiffer.
There are some exceptional finds around with a little bit of investigative work.
Ultimately, it's whatever lights your burner, rag tops or coupes.
I like the coupe, personally. I don't care about track days.
      11-18-2016, 06:43 PM   #10
prototype55
Drives: n/a
I am leaning towards the roadster as of right now and thanks for the replies guys I have learned a lot already.
      11-20-2016, 08:45 PM   #11
Rick F.
Rick F.'s Avatar
948
Drives: 2013 BMW 335i cabriolet
Prototype,
Just a couple of other thoughts: First, many track-day organizations won't allow roadsters, even if they have built-in roll bars like the Z4. Second, the roadster's top holds heat just fine in my experience. The heater is great, and I defy anyone to leave the heated seats on the three-bar setting for more than a few minutes. One bar only is usually plenty! Finally, there is no question but that the Z4M is a monster sports car. At the same time, the 3.0i and 3.0si are great cars, too. Unless you really want the hyperspeed capability of the M, you might take a look at the other models, too.
Happy researching and shopping!
Rick F.
      11-20-2016, 09:17 PM   #12
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
Originally Posted by Rick F. View Post
Prototype,
Rick F.
SCCA, Hooked on Driving, and CHIN allow soft tops in their PDX/HPDE events. Most everyone else, including BMWCCA, don't but you can do 1-2 events a month year round with the groups that do allow it.
Top Down 365
