      09-25-2015, 08:34 AM   #23
F360C
Drives: E86 S54
I have a couple stupid questions to help you diagnosis this issue.
1. Does the car have the MAF hooked up? I know with the ESS supercharger kits they get rid of the MAF but I am assuming it was put back in when they did the engine swap
2. Can you confirm that the car has the correct pre-cat o2 sensors? The e46 M3 uses a slighty different pre-cat 02 sensor then the Z4M. The first picture below is a Z4M precat 02 sensor is the second picture is a E46 M3 precat 02 sensor. As you can notice the connectors on the two sensors are completely different. If they used the engine wiring harness from the M3 they would have had to have used the M3 02 sensors. My only hesitation with saying this as a possible issues is I am not sure if the M3 engine harness would hook up to the Z4M DME. Now if the m3 engine harness does hook up to the z4 dme this could be why all your pre and post cat 02 sensors are getting faults and also your BSD line faults.
3. Has your shop tried to scope the BSD line fault? To me and dealing with these issues on a regular basis the BSD line fault might be the cause of all your issues. I believe on our cars the oil level sensor is on a BSD line.
4. Have you tried going to the dealer and asking them to flash the car with stock software? I think at this point you should try and make as many things stock as you possibly can to eliminate issues.
Edit: Forget #4.... just saw you tried this.
07 Z4 M Coupe AW/IR
      09-25-2015, 02:13 PM   #24
BGR
Drives: C7 GS 7MT; e90 M3 6MT
Replaced the throttle actuator based on the code below, but unfortunately the problem persists.
Internal fault monitoring air path, impassible
2D51
      09-25-2015, 08:45 PM   #25
BGR
I'm racking my brain why it would have happened to abruptly, and right after a reflash of the DME. There are no signs the DME itself is bad (which maybe is a sign?). The car was running nearly perfectly. Parked it. Next day reflashed the DME. That night went to take it out and it wouldn't go above 1500 rpm.
      09-25-2015, 08:55 PM   #26
BGR
The car in its current state is running super rich. Is the computer detecting it is running super rich then chopping the throttle at 1400 rpm as a safety mechanism? What would be causing it to run as rich as it is? It's like it thinks there is more air getting into the engine than there is so its dumping fuel. Like there is a supercharger on it. Could there be any way it still thinks there is a sc on there?
Could overall timing be off within the engine somehow?
      09-27-2015, 10:02 AM   #27
BGR
I keep coming back to the DME as the fault for all of this, but that is a $2k replacement.
      09-27-2015, 04:33 PM   #28
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Try unplugging the MAF to put the car in speed density mode. Be gentle with the throttle, especially before it's warmed up.
      09-28-2015, 01:00 PM   #29
BGR
Might have a lead. Stay tuned. Something I thought was checked as one of the first steps when diagnosing...
