      09-13-2015, 10:50 PM   #1
3002 tii
3002 tii's Avatar
2282
Mismatched Tire Heights
If I run taller tires up front (235/40-18 vs 255/35-18), will I constantly be setting off DSC?
Follow for latest mods
      09-14-2015, 02:25 AM   #2
Westersund
Westersund's Avatar
Sweden
496
Drives: BMW
Don't know how wide you wheels are (I put in 8" front and 9" rear) but it won't trigger the DSC. I think the difference have to be 4% or above for the DSC to trigger, the specs you stated are only 1,5% difference in front vs rear.
http://www.willtheyfit.com/index.php...et2=35#content
      09-14-2015, 03:26 AM   #3
3002 tii
3002 tii's Avatar
2282
I should've been more specific but I was referring to tire height, not width.
235/40-18 = 25.3"
255/35-18 = 25.0"
      09-14-2015, 03:39 AM   #4
Westersund
Westersund's Avatar
Sweden
496
Drives: BMW
235/40-18 = 25.3"
255/35-18 = 25.0"
Put in all the correct values in the URL I provided and you will see the difference, if the circumference difference (front to rear) is below 4% you'll be fine. And the width of the rims and tires do matter in calculating the circumference, not only the height of the rim and tire.
      09-14-2015, 03:51 AM   #5
3002 tii
3002 tii's Avatar
2282
I did click on the URL but I don't see how rim width makes a difference. I tried 3 different widths (9, 9.5 and 10") and the height was same each time (and I never mentioned using different diameter or height rims). Either way it seems like you answered my question.
      09-14-2015, 04:00 AM   #6
Westersund
Westersund's Avatar
Sweden
496
Drives: BMW
A wider rim, without a wider tire will stretch the tire making the circumference smaller. Seems like the calculator doesn't take into account for a stretched tire.
      09-14-2015, 07:27 AM   #7
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
You will not set off lights.
E60 ///M5 - (6 Speed) Silverstone Metallic/Black
F06 640iX - Tanzanite Blue/Amaro Brown
K66 ///M1000RR - Competition
      09-14-2015, 07:00 PM   #8
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
I've been running 255/35 x 18 (25.0" diameter) up front, and 275/35 x 18 (25.6" diameter) in the rear. I've done a couple track sessions and to date the only time DSC came on was when I hit some coolant the car ahead of me vented in a tight, medium speed curve, and I suspect DSC would have been triggered there regardless of tire diameter.
Top Down 365
