09-15-2015, 01:21 PM | #1 |
Rep 149
Improve brake pedal feel? BBK?
I have an '07 Z4Mc running stock rotors and calipers with PFC 06/08 pads and SRF fluid. The stock set-up is plenty of brake for me and I haven't had any fade at the track with fresh fluid but I'm not getting a lot of feel through the brake pedal. To me, it generally feels soft, a little grabby at the top, and has a longer/lighter travel than I'd like. I've had a few people drive my car and they seemed to think the brakes felt fine so it definitely could be that I'm just used to old cars with heavy pedals. In my e28 M5 we swapped in the master cylinder from an e32 and changed the rear calipers for more rear brake bias and that felt amazing on the track even though the actual braking performance wasn't that much improved or even really all that great by modern standards.
Has anyone done anything to get a stiffer, more progressive, brake pedal feel? For those that have gone to an aftermarket BBK kit, did the feel through the pedal change significantly (for the better)? TIA! |
09-15-2015, 02:30 PM | #2 |
Rep 187
From what I've heard, some people say that cycling the ABS pump during bleeding can make a big difference. It's one of my major complaints with the car also, and sadly there don't seem to be any oem sized 4-piston caliper upgrades. The car has heavily boosted brakes, and I always find it hard to jump from my e30 to the z4m. Of course the Z brakes are more powerful and resistant to heat, but the e30 brakes feel worlds ahead in terms of feedback and ease of modulation.
With the cost of the full BBK options that are out there you damn well better know you want them before investing!
1990 332i 5 speed (OBD2 S52 Swap)
2018 VW Golf R (6spd manual/copper orange metallic) 2008 KTM SuperDuke 990 2007 Z4M Coupe (#1026/1815) SOLD |
09-16-2015, 02:35 PM | #3 | |
Rep 1,373
I am thinking I am going to do it to my car over the winter.
07 Z4 M Coupe AW/IR |
09-16-2015, 03:57 PM | #4 | |
Rep 149
09-16-2015, 05:44 PM | #5 | |
Rep 187
09-16-2015, 05:47 PM | #6 | |
Rep 10,647
http://www.rallyroad.net/ |
09-16-2015, 06:16 PM | #7 | |
1820
Rep 5,337
You can run 1mm shims behind the pads to prevent this issue, but you will have to work with RB to get them to release the kit to you without their rotors.
09-16-2015, 06:36 PM | #8 |
Rep 407
I did a quick search and found a bunch from the e46 guys have already done it:
http://m3forum.net/m3forum/showthread.php?t=455631 Is this the same process for our M's? |
09-16-2015, 07:03 PM | #9 | |
Rep 10,647
09-17-2015, 01:57 PM | #10 |
Rep 231
Been having the same issue with my brakes. Stops fine but pedal travel makes it almost impossible to heal-toe. This sounds like an interesting solution.
09-18-2015, 09:08 AM | #11 | |
Rep 1,373
1. The pad does not sweep the entire surface of the rotor which leaves a visable rust ring on the rotor. This is well documented if you search "RallyRoad rust ring." A member of M3Forum "p0lar" went through alot of trouble to design a new bracket that eliminates this issue. If you contact him he will sell you the brackets. 2. The RallyRoad bracket contacts the upper bolt on the control arm. Again well documented on M3forum. The "p0lar" bracket fixes this on the M3 but it does not fix it on the Z4M. The p0lar bracket still contacts the bolt on our cars so alittle grinding if the bracket is needed. I just used a dremel tool and was able to make clearence. Although both brackets have an issue with contacting the upper control arm bolt and will need grinding the p0lar bracket does eliminate the issue of the pad not doing a full sweep of the rotor surface. p0lar being the genius he is also did alot of calcuations on pad size, pad shape and piston size on the 996/cayman s calipers to determine brake bias. With 996/cayman S pads being used on our cars it shifts some of the brake bias forwards not unlike the brembo BBKs for our cars. He was able to find a different pad combination that moves the bias a bit rear wards which is close to the stock CSL brakes/ AP Racing BBK brake bias. I found this helped alot under hard braking at the track as it makes the car a bit less skiddish under heavy late braking. I am not sure of the exact pad shapes we ordered but I am sure a PM to p0lar and he will be able to let you know. Or I can look at the part number on the pad boxes when I get home. In the end my brother set up is as follows.. Front: 996/Cayman S caliper (5mm of the mounting boss must be machined off, Rally offers this service or any machine shop can do it.) Rally Road Bracket Rally Road Brake Lines Stock CSL/ZCP Rotor Rear: 996/Cayman S rear caliper p0lar Bracket Rally road brake line Stock CSL/ZCP rotor *****Now looing at the Rally Road site they state to have redesigned their caliper bracket to eliminte the issues mentioned above.
09-27-2015, 10:48 AM | #12 | |
Rep 196
Insert 4 long bolts into the new pedal pad and use washers to raise the height of your brake pedal to an acceptable height. Put the bolts through the original pedal pad and install nuts and tighten. Then install the Pedal Pad Cover onto the new pedal pad and you will suddenly have a brake pedal who's height will match that of your gas pedal so you can roll the outside of your right foot onto the accelerator pedal for heel/toe rev matching. And no one but you will know that you modded it. Of course, then send me all the money you saved on not having to purchase a big brake kit to me as thanks!
09-28-2015, 10:30 AM | #13 |
1621
Rep 4,294
I had issues with pedal feel aswell, but my brakes had 200K on them, after i swapped to Stoptechs steel braided brake lines and pads, and a brake rebuild, its a complete other story. love the feel.
Crap, disregard if the issue isn't feel...
Powered by Last edited by Vanne; 09-28-2015 at 06:20 PM.. |
01-05-2016, 09:57 PM | #15 |
Rep 231
All joking aside. I'm still dealing with this issue. Unfortunately, I haven't driven much because of the weather. I ordered a new master cylinder just to feel like I'm doing something. As the weather gets a little better maybe I can get it out and try to actually diagnose what is going on. If you have any suggestions on some technics let me know.
01-06-2016, 08:30 AM | #16 |
Rep 5,327
i need to get back behind the wheel of my ///M because i can't exactly remember what the modulation of the brakes of the AP bbk is like .... what i do remember is braking is much stronger and the pedal feel is better, but when they are cold they feel pretty shit imo.... This may be a characteristic of large brakes with multi piston setup from cold?? or my race Pads.
Once warmed up, they feel, and brake better than anything I've driven, the warmer they are, the better all the reference points mentioned feel.
01-06-2016, 04:46 PM | #17 |
Rep 11,667
^ it's your race pads, they require some heating up to work properly.
I swap mine out with street pads in between track days. (Another benefit of having top load BBK fixed calipers)
01-07-2016, 11:50 AM | #18 |
Rep 149
I actually like running race pads (running pfc06/08) on the street - the lack of bite when cold makes the brakes feel less grabby
I'm driving ceramics on the cayman and they are also grabbier than I would like but at least the pedal is heavier and has more feel. Fwiw, my e28 M5 had small oem 4 piston fixed calipers on the front and sliding upgraded single pistons at the rear, not as feelsome as the Porsche but way firmer and half the pedal travel which was awesome for heel toeing. I'm thinking maybe the only option is to go with a bbk for some fixed calipers... Last edited by ajw45; 01-07-2016 at 02:37 PM.. |
