      05-04-2016, 07:38 AM   #1
HankDKrank
Seasoned Novice
HankDKrank's Avatar
Drives: 08 Z4 Roadster
3.0si Fan Shroud Removal
I am about to replace my oil cooler gaskets and don't know how much work it is going to be to remove the fan shroud. Has anyone done this and do you have any tips? I looked around and haven't seen any DIY or video on that step. Thanks, Hank.
.HanK.D.KranK.
      05-04-2016, 12:00 PM   #2
Karacticus
Karacticus's Avatar
Drives: 2007 Z4 3.0si Coupe
If you're talking the plastic cover over the radiator, my recollection is that it's pretty straightforward.
There's the two torx machine screws, one on each side, and then unscrew/pop out the plastic expanding rivets around the perimeter. It's probably a good idea to pick up a replacement set of the latter, as the heads/fasteners may strip out while unscrewing them, or they just break.
You'll probably want to back off the big torx inserts that hold the radiator in place before you re-install the cover, then snug them back up.
The expanding plastic fasteners will re-install easier and hopefully be better removable in the future if you put a (very small) dab of silicone grease on the threaded portion before inserting them.
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters
      05-04-2016, 12:21 PM   #3
Karacticus
Karacticus's Avatar
These are the plastic expanding rivet things....
2007 3.0si Coupe
      05-06-2016, 12:13 PM   #4
HankDKrank
Seasoned Novice
HankDKrank's Avatar
Thanks Karacticus - I don't really know what to expect so will probably just tear into it this weekend. It looks a little tight for space is all.
.HanK.D.KranK.
      05-07-2016, 10:26 AM   #5
onthe3rdday
Drives: 07 Z4C
The fan shroud is incredibly simple to remove. You will not spend more than 10-15 minutes. The radiator stays (LARGE TORX) dont get touched. Once the cover is off removing the fan assembly is a matter of one electrical connector and two screws up top. Super simple
      05-08-2016, 11:22 AM   #6
HankDKrank
Seasoned Novice
HankDKrank's Avatar
Thanks - got-r-dun yesterday. Front cover was a piece of cake - two of the plastic rivets broke on reinstall but they are in and holding. Once that was off I saw that the front brace made things very tight space-wise. Did not remove fan. Back bolt on filter housing was a bear - had to go buy a 1/4" swivel and 1/4 to 3/8 adapter. Should have had a 1/4" E10 socket but got-r-dun using my rigged up 3/8 socket. Back together, oil change, cleaned all up - about a six hour job - but I take my time. If had to could do it in two - but that's not the way I roll. More garage wall art too - name that road course.
Side note - I will never again turn the oil filter cap unless I am removing or installing it. I turned my about 1/8 turn (back and forth) after changing gaskets and before testing and it would not stop leaking - bad. Once I changed oil and had new o-ring in there it's all good again.
.HanK.D.KranK.
