12-09-2017, 05:00 PM | #1 |
Rep 2,138
Drives: Me
Playing with some trim pieces
I bought a 3D Printer about a month ago and I have been on the extreme learning curve ever since.
I remembered that one of the interior trim covers down by the seat (on the tunnel) is missing. Yea, I can just order a couple of new ones but..... lets try something.... I need to smooth the finish but they FIT and actually look good. |
12-09-2017, 08:13 PM | #3 | |
Rep 1,692
3GFX722.50 |
12-10-2017, 09:22 AM | #4 | |
Rep 2,138
Drives: Me
The issue is you have to provide the 3d model to feed into the slicer....to do the print. If I had to do the model, then you do not have enough money... |
12-11-2017, 06:07 PM | #7 |
Rep 2,138
Drives: Me
You know these are order-able parts.
Item 19. http://www.realoem.com/bmw/enUS/show...diagId=51_4931 Like I said, these fit (very tight) but you can tell that they do not belong. Different plastic and they are not smooth. You will most likely break them getting them out because the PLA plastic I used is stiffer than what BMW uses. It was mainly a test for the actual print for small parts. I printed these with a layer height of .2mm. At this resolution, it takes 15 minutes to print just one. I might try this a .1mm layer height but that will bump the print time to 25 minutes each. |
12-12-2017, 07:35 PM | #8 | |
636
Rep 3,124
When I need things like that I just collect up a "wish list" and buy them with my next order of oil and filter.
12-13-2017, 08:48 AM | #9 |
Rep 528
Drives: E86 Z4MC; E92 M3
My Z4MR was missing the passenger side cover as well. Ended up going to the dealer with a P/N on hand from RealOEM, they then told me that it was a different part number for my car.
Cover they ended up giving me never fit right and square in the hole, and was obviously a different texture/colour than the driver's side + tunnel. Figured they screwed up and I had the part number right myself. But there was no way I was removing it without breaking it so I let it be.
E85 Z4M Roadster Imola Red/Black GONE E90 M3 Sedan 6MT Jerez Black/Fox Red GONE E86 Z4M Coupe Interlagos Blue/Black E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread |
12-13-2017, 09:32 AM | #10 |
Rep 1,991
Mine was missing on the passenger side when I bought mine in 09. I was able to get the correct part from my dealer and it has been fine since.
12-13-2017, 10:27 AM | #11 |
Rep 2,782
Does the printer have the resolution to print the BMW Roundel on the top?
If it can't be made to be identical, embrace the difference
12-13-2017, 11:30 AM | #12 |
Rep 2,138
Drives: Me
12-13-2017, 12:47 PM | #13 |
Rep 758
Nice! The capability of the low cost 3D printers is amazing. I bought a Robo3D last year for work and it paid for itself the first day. It consistently held +/- .005" on the parts we printed, and it lasted 11 months before it had an issue (Controller board died due to a power brown out. Cleaning crew had unplugged the printer from it's UPS and plugged it back into a wall socket. ). We had printed off about 400 different parts at that point. I paid $699 originally so our cost was less than $2 per part. Going to an outside service we would have paid $200 - $1000 each for those parts.
Price for it now is $399 from Amazon so it's an even better deal now. As Shipkiller indicated, the big work is getting to the point where you have a step file from a 3D model to feed into the printer software. The good news is if you're enrolled in any kind of college course, you can get a cheap or in some cases free copy of AutoCAD. https://www.amazon.com/Assembled-3D-...eywords=robo3d
Top Down 365
12-13-2017, 02:32 PM | #14 | |
Rep 528
12-13-2017, 02:47 PM | #15 | |
Rep 2,138
Drives: Me
I paid $350 for my Creality CR-10 printer in November. Damn its been fun so far.. Autodesk's Fusion360 is free to individuals and students... |
12-14-2017, 01:19 PM | #16 | |
Rep 758
Top Down 365
12-14-2017, 08:10 PM | #17 |
Rep 2,138
Drives: Me
Until this point, I had exactly zero experience with 3d modeling. The learning curve is steep but enjoyable.
What is a challenge is that different brands of filaments print differently, requiring different settings to get it to work satisfactorily. Even different colors of the same brand will not print like a different color of the same brand. And that is just using the same type of filament. I am currently only using PLA but the wife has bought me several rolls of ABS and Nylon for xmis... keep this quite...I am not suppose to know... I am currently using Simplify3D as my main slicer. For those who do not understand, slicing software converts the 3d model into G-code (a subset of CNC code) so your printer knows how to print the model. I have picked up Ultimaker Cura 3.1 and have started to mess around with it. S3D is still my main slicer since I understand how it works. I also setup a spare Raspberry Pi 3, installed Octoprint on it and the RP3 is now my printer control engine so I do not have to have a big computer running to do the print. So far the largest print was 13 hours long. I do not like copying the .stl file to an sdcard to print. There must be over 100 different types of 3d printers on the market. I spent a whole month doing research on (and adjusting my expectations downward) what I wanted in a 3D Printer, in the price range I was willing to pay... This is really some cool shit. |
12-14-2017, 08:53 PM | #18 | |
Rep 758
On the dryness issue, most of the plastics that flow well for 3D printing also tend to be slightly hygroscopic so if they haven't been stored with desiccant or some other means of keeping them dry, that changes the flow a bit also. Might not be as significant for you where you are as it is for us here in the sub-tropics.
Top Down 365
12-15-2017, 04:23 AM | #19 | |
Rep 2,138
Drives: Me
I built a sealed dry-box that has a portable de-humidifier installed. It will hold two spools and the entire path from the box to printer is sealed (in PTFE tubing) so the filament in use stays dry. |
12-15-2017, 07:31 AM | #20 |
Rep 4,058
A late comment on those trim covers - I had the same issue with my car, so I bought a new one and popped it in place. Less than a year later, it came out, apparently because one of the tabs on it had broken off. Fearing that I had damaged it when I installed it, I bought another and the dealer tech amiably obliged my request to pop it in. Despite that, the second one fell out due to a broken tab 6 months later. I can only conclude that the OEM part is just flimsy, or at least the retaining tabs are. I think that a good approach may be to apply a couple of small dabs of glue or clear silicone to the back of the piece when installing to be sure it stays in place (not too much to make a mess or in case you need to remove it in future).
Huz-Z
