07-25-2013, 09:19 PM | #1 |
445
Rep 1,658
Two new APEX ARC-8 17x9.5" Wheels with new 255/40/17 Toyo R888's
These were used only as display wheels in our bimmerfest booth on our E90 335d. Tires were mounted but not balanced. The wheels were bolted to the car at the show and removed. There are zero miles on the wheels and tires. Tires are new Toyo R888's in 255/40/17 sizes on them. The wheels are ARC-8 17x9.5" ET35 in the Satin Black Finish. These can be used as part of a square or staggered setup on the Z4 M. A front spacer of 5mm will most likely be required to clear the strut tube due to the meaty sidewall of the R888. Negative camber will be needed to keep this setup under the front fender. This is an easy fit on the rear and can be spaced out for aesthetics or run spacer free. Maximum 6" length main springs up front and no helper springs, so KW variant kits, and other kits with long main springs will need a spring swap to work. Ground control, TCK, JRZ and many others can work with 6" springs. They can fit many other applications as well. contact me for fitment details/advice. Tires were $408 plus shipping and mounting new for the pair, and wheels are $269 each new, for a total of $946 without the shipping and mounting. Selling the pair for $800 plus actual cost of shipping on our discount company account (can range from 30-100 depending on location). Can also ship with two new wheels from APEX stock to complete the set. CA buyers pay sales tax. |
07-25-2013, 09:46 PM | #2 |
Rep 12,565
So tempting...
