View Poll Results: Are you interested in an anti-Drone product?
Have no/little drone; not interested 12 24.00%
Interested in 'Tuneable' anit-drone - @ Budget Cost $200 25 50.00%
Interested in 'Tuneable' anit-drone - but $200 is too much 13 26.00%
Voters: 50. You may not vote on this poll
      08-06-2013, 06:51 AM   #1
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
...closed....
I had a brief discussion with the guys at DKF regarding an anti-drone product for exhaust systems.
The concept is to take industrial engineering practice and apply it to automotive exhaust systems.
The idea is to tune out the drone at the source before it resonates and vibrates body panels and parts.
Simply put, it would be a kit that would form a ring which clamps around the exhaust pipe.
By rotating the position of the ring as well as selecting different parts of the kit, you find the right 'tune' that dials out and cancels the drone.
There is considerable R&D to be done before this could be made available, and DKF is looking for some input on a couple of things so that they can decide to proceed or not.
- Need; is there enough interest to develop this product?
- Cost; what do you consider an be equitable cost for a product that tunes out drone?
Trying to keep the poll simple, but please feel free to add comments re cost etc in the thread.
      08-06-2013, 07:01 AM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Also....
Anyone with a Z4M in Tampa Bay area interested in test fitting DKF product(s) ????
Drop either Doug or G an email.
Giovanni Souza AKA Diokaef
souza.inc@gmail.com
Doug Davis
dkfperformance@gmail.com
      08-06-2013, 07:21 AM   #3
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
One thing I think a lot of people would be worried about is weight. This thing could completely eliminate the drone, but if it weighs too much it wont sell.
Also it has to be easy to install.
I would definitely be interested. Love the sound of my RPIs, just not when I'm cruising on the highway.
      08-06-2013, 10:59 AM   #4
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
I put down that I'm interested at $200. But for that cost, it should actually greatly reduce my drone, not be something that "might" work for some people, or have only a small difference in drone.
If it truly cuts down my drone a good amount, I'd gladly pay $200.
I have a LOT of drone. If only they were closer to Chicago I'd stop by for test fitting.
      08-06-2013, 11:37 AM   #5
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Price is more of an outside limit... in all likelihood it will be less than than 200
This is intended to be MUCH more than a band-aide solution.
The idea is to be able to tune it out.
That's why its NOT a one size fits all cure all.
The buyer has the ability to tailor it to his particular exhaust.
LMAO.... just noticed I fail at spelling Anti- in the poll questions
      08-06-2013, 11:41 AM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
There is definitely a little added mass.
The weight will be less than a lb.
      08-06-2013, 11:49 AM   #7
intoflatlines
What would it be? An adjustable helmholtz (sp?) resonator? How easy would the install/adjustments be?
Like I said, I have a lot of drone. It's so bad that I have earplugs in the car for if I do any highway driving. Above 4K RPM it sounds amazing though
      08-06-2013, 11:54 AM   #8
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
DKF is working on some drawings that will be posted.
      08-06-2013, 12:12 PM   #9
gmbbs
Drives: TBD
If it's anything like the rest of a DKF system, weight is not a concern. thier system is a flyweight!
      08-09-2013, 08:30 PM   #10
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
      08-10-2013, 10:52 PM   #11
txz4
txz4's Avatar
59
Drives: 2006 M coupe
i would gladly pony up 200 for something like this assuming it worked EXACTLY as advertised.
      08-10-2013, 10:52 PM   #12
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
I have drone while my engine is labouring, either due a wrong shift (too low rpm) or a lazy cant be arsed to shift down a gear.
How would this work? There are sooo many variants of pipe out there?
Very interested though.
Powered by
      08-11-2013, 10:50 AM   #13
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
200 bucks for RPI volume, pops and bangs but reduced drone? I'm in!
      08-11-2013, 12:40 PM   #14
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Sounds, no pun intended, like it could be a win. For example, I really liked my Diablos, but the drone was a deal breaker. Other cans are out there, but typically über-expensive. Such a product, if "tune able" to cancel resonance, would have more than a Z4 application. (S65 has the same tendency to drone.)
      08-11-2013, 09:01 PM   #15
Urluz3n
Lackey
Drives: 07 BMW M Coupe
"I have drone while my engine is labouring, either due a wrong shift (too low rpm) or a lazy cant be arsed to shift down a gear.
Very interested though."
Just like mine
I would spend $500 if my drone goes away!
I installed a cat less header on my M Coupe a few weeks ago and then I had Active do a tune on my ECU. Now the drone is killing me! It seems to occurs always around 2000 rpms. I am considering exchanging my Stromung for my oem mufflers. Maybe the drone will ease up. Unless someone has a better idea.
      08-11-2013, 09:13 PM   #16
jophish17
jophish17's Avatar
58
Drives: Z4MC
Don't drive at 2k rpm!
      08-11-2013, 09:54 PM   #17
Urluz3n
Lackey
It is not that easy
      08-11-2013, 11:12 PM   #18
StickMon
StickMon's Avatar
Drives: 2006 MR
I love my Diablos. I really don't get the drone thing.
I bought them so they would make a racket, and they do.
I guess I spent too many years driving a ricer with a FlowMaster.
(Think really big leaf blower.)
Maybe it's worse in the coupe than the roadster.
      08-11-2013, 11:38 PM   #19
Z4inAZ
Drives: Z4 2.5 03
Yeah, take a car with a droning exhaust on a 2,000 mile roadtrip then try to tell us you still love em!!!
Car modifying is about improving things, not just changing them
      08-12-2013, 11:23 AM   #20
intoflatlines
I had to drive 2 hours on the highway to a remote office for work today. Luckily I keep earplugs in the car. I've got 2 more hours this afternoon :/
I'm hoping this product is legit and actually works. I would pay so much money to have the exterior sound of my exhaust without the incredibly terrible interior drone!
      08-15-2013, 03:46 AM   #21
Urluz3n
Lackey
Just changing out the mufflers doesn't necessarily give you a drone. When I just had my stromung mufflers I had a really good sound with no drone. Once I installed the the headers I got the drone.
      08-15-2013, 11:40 AM   #22
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Discussions on drone often head down a few different paths as people often have a different idea of what drone is.
Drone is a high amplitude sinusoidal oscillation of the exhaust gases in the exhaust pipe.
A droning exhaust system works something like a single note pipe organ.
When it hits a certain frequency (e.g. ~125 Hz), it rings out loud and causes what is known as drone.
So the idea of an anti-drone product is to tune in to 'that' frequency and convert that energy to another form to cancel out the drone.
Drone is not just noise or a loud exhaust.
