02-04-2013, 03:22 PM | #155 | |
Rep 892
lol
Thanks, I will do runs on the dyno with the meth turned on and off.
02-04-2013, 06:01 PM | #157 | |
Rep 892
02-04-2013, 06:45 PM | #158 |
Rep 917
Entire kit weighs 113lbs (Vac Motorsports). This sound about right?
Andre - 2J into a Z4 Coupe!
02-05-2013, 01:25 AM | #159 |
Rep 892
I'd say about 80-85 lbs taking into account the parts that were removed.
02-07-2013, 02:07 PM | #160 |
Rep 441
trying to be sure i know what the 570 bas over the 480 kit....bigger injectors, mafless tune, smaller pulley, spring tensioner upgrade, and requires headers.....is that it?
02-07-2013, 03:18 PM | #161 | |
Rep 892
02-07-2013, 09:19 PM | #162 |
Rep 441
thanks...I literally just signed the papers on my m coupe today, so I am still a ways off from pulling the trigger on it haha...just want to be informed
02-08-2013, 07:04 AM | #163 |
Rep 917
RatedM: Can you verify the diameter of your supercharger pulley? And I assume it is 6-rib...
03-05-2013, 12:11 AM | #164 |
Rep 892
No real updates as I've been pretty busy, but I did order some parts to get it ready for track season.
Ordered some PFC 08 pads and Motul 600 (last time at the track I boiled my brakes every session). I also order a Setrab oil cooler with all Setrab fittings, black SS lines, and the VAC adapter. I haven't had any cooling issues with the stock oil cooler, but I don't like how the oil cooler and intercooler are arranged. I'm going to put the new oil cooler behind the kidney grills like the ESS kits and move the intercooler forward to get all the air from the lower grill. I'll also be getting the P3 vent gauge so I can monitor IAT (without having my laptop in the passenger seat) before dropping another $1100 on an aquamist meth kit.
04-04-2013, 11:55 AM | #165 |
Rep 892
Forgot to post an update from the track day. Oil temps stayed right at 230 degrees with the new Setrab. The only problem I had was a little oil coming out of the vent plug of the SC, though it was still at the max level when I checked. Also, the new PFC pads still started to fade after 20 minutes; going to have to look at some form of ducting.
The kit has 3k miles on it now and is running strong. I also took out and bypassed the water reservoir for the air-to-water system; saving about 25lbs off the front end. Now I'm just waiting on the P3 gauge to ship.
04-04-2013, 12:10 PM | #166 |
Rep 428
Arent you worried about heak soak by removing the aftercooler? Seems the power lost and weight savings would be worse than sustaining power and an additional 25 pounds, no?
04-04-2013, 12:44 PM | #167 |
Rep 892
I should have clarified. The system has an additional ~2 gallons of coolant in a reservoir under the car (E46 M3 setup). I just removed the reservoir and ran the lines straight to the intercooler (E9X M3 setup). The system still works the same way (just with half the fluid in the system) and should provide the same cooling.
04-05-2013, 05:25 PM | #168 |
Rep 892
Bimmer Magazine article: http://www.bimmer-mag.com/issues/115...black-and-bold
04-05-2013, 08:26 PM | #170 | |
Rep 1,031
04-06-2013, 03:56 PM | #171 |
Rep 33
Catless is lost too. Red line: cat oem, Oem Xpipe, terminals Supersprint Race Green line: catless, Xpipe Supersprint, terminals Supersprint Race Black line: how the green line with 50% meth 50% water (start 2psi, full pression 6 psi) The gain (6000-8000) not compensates for the loss (4000-6000). |
04-06-2013, 05:25 PM | #172 | |
Rep 892
Thanks guys!
04-06-2013, 09:02 PM | #174 |
Rep 33
For this reason. Catless effectiveness depends on DME (crossing valves time). I hope that your DME is in tune. mine is not. I don't want to belittle your car. If I'm wrong, I request that be deleted. Write a thread. Last edited by pandusr; 04-06-2013 at 09:21 PM.. Reason: quote |
04-06-2013, 09:39 PM | #175 | |
Rep 892
04-06-2013, 09:47 PM | #176 |
Rep 33
Ok !!!
Z4M E85/2006 || ESS CFR525 || AEM Water / Methanol Injection Kits || Supersprint Exhaust (catless,XPipe,rear exhaust race) || 4.10 || front brake AP Racing 6 piston kit (cp5575-1010) || K-Sport suspension with camber plates || Sparco Pro2000 seat || 6 pti Sparco belts -|| Hankook S1 EVO 1 (front 245/35 19 - rear 275/35 19) || OZ Racing Ultraleggera HLT 19"
