      06-18-2013, 02:57 PM   #1
D Nice
Drives: 06 BMW Z4 3.0si
Suspension Noise-Loud Knock
Want to see if any of you guys can help out here. I'm having a loud clunk or knock from my front suspension every time I go up a steep driveway or parking lot entrance. It only happens when I enter in an angle. It seems to come from the firewall. From research that I've done it seems like loose strut bars from the fire wall to strut towers. I've read on the repair manual that these should probably be re-torqued. Torque values on the manual state 41 Nm for the nut. Replace the screw 56 Nm with a torque angle of 105 plus/minus 15. Has anyone tried to tackle this themselves. Any suggestions, should I try this myself or take it to a shop.
      06-18-2013, 05:01 PM   #2
seank
enthusiast
seank's Avatar
48
You can tackle it yourself. It could also be:
-loose sway bar link, loose sway bar
-from the struts, especially if it is double adjustable
No shop needed at this point.
      06-18-2013, 07:13 PM   #3
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Well published noise on forums since 2006. I never found what caused it. Only happened at my old office on the entrance to the parking garage.
2006 Z4MC - #LL93158
      06-18-2013, 08:10 PM   #4
beta
Drives: 2006 M Roadster
Easy to do. Note that it's either a nut or a one-use bolt. Since you have an 06 you more than likely have the nut kind, the bolts should not come lose since they are one-use.
Look in my mod thread in my sig for part numbers for Nord-Locks if you have the nuts and want to make sure they stay put.
      06-18-2013, 08:23 PM   #5
D Nice
Thanks for the input guys. Going to take a look this weekend since its not my daily driver. From what I've seen it has nuts on the firewall. Should they be replaced also or just re-torqued.
      06-18-2013, 09:22 PM   #6
D Nice
Look in my mod thread in my sig for part numbers for Nord-Locks if you have the nuts and want to make sure they stay put.[/QUOTE]
Beta, the Nord-Locks, are they just for firewall or firewall and strut tower?
      06-19-2013, 01:32 AM   #7
beta
There's always nuts on the firewall side, what changed is the strut tower side.
If you have nuts, it's the same nut on all 4 corners. If you have bolts, you could try replacing them but it's less likely to be your problem. Worth a shot though.
      06-25-2013, 10:51 AM   #8
D Nice
Thanks for the help guys. Re-torqued the firewall nuts and everything seems to be fine. Don't hear any noises at all. Thanks again.
