      05-26-2018, 03:44 PM   #1
NISxMO
Drives: Looking to purchase soon!
HELP! Has anyone replaced their Vanos Filter?
I just did an oil change and was replacing the Vanos filter. Watched an ECS video and seemed easy enough. The kit came with a vanos filter, larger o-ring, and a small o-ring. Replacing the large o-ring and filter is no big deal, however the small o-ring must be pried off (as it was also done in the video).
Unfortunately there is a white plastic collar that is also beneath the small o-ring and broke the same time the o-ring did. I have no idea how someone could remove the small o-ring without breaking this collar.
Looking at parts schematics, the collar doesn't even appear in the diagrams. Now I don't know who to proceed. Anyone have experience with this?
Thanks!
      05-26-2018, 10:31 PM   #2
Cyclops
Cyclops's Avatar
I can't remember exactly what that looks like, can you post photo of what you mean.
2007 #1432 ///M Coupe Silver Gray - H&R Coilovers - AFE Intake - Strong-Strut Brace - Super Sprint Race Exhaust & Xpipe - 19" Avant Garde M359 - Stoptech 380 6 pot BBK @instagram
      05-27-2018, 03:46 AM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
I seem to remember from the videos, you're not supposed that break that part.
I don't think it's available separately.
A warning to others:
I've changed mine a few times, and I think it's mostly a scam.
The only time I've had any swarf was after breaking a Vanos exhaust hub tab.
Only change it after you've had some sort of abnormality that will produce swarf, like breaking a tab.
mainsoda111.50
      05-27-2018, 07:48 AM   #4
NISxMO
Thanks Guys! After going to the auto parts store and finding an identical collar for a power steering system then proceeding to break that too trying to get it on, they looked up a brand new Vanos bolt and some of the images show that collar as having a cut in it.
I dont think it can go on without being split. Because of this, I just threw it back in the car with new o-rings, filter and split collar and so far so good. The 45 degree cut made it seem like I didnt break it after all
      05-28-2018, 10:01 PM   #5
mainsoda
mainsoda's Avatar
Drives: 2006 BMW Z4M coupe
      05-29-2018, 04:46 PM   #6
StickMon
StickMon's Avatar
Drives: 2006 MR
swarf
swrf/
noun: swarf
fine chips or filings of stone, metal, or other material produced by a machining operation.
"a curl of metal swarf"
Oh, and my Dimple magnetic oil drain plug came out with a pretty full beard after the hub tab breakage.
Search this Thread:
Advanced Search
