06-02-2010, 01:19 PM | #1 |
Rep 139
Z4 Wind deflector - Looking for instruction
I have the oem mesh one that hangs over the hoops.. can't find instruction anywhere.. found mentions of it but no instructions. If anyone has hints or something.. or if you have the actual instruction, ill host it.. Thanks
06-02-2010, 11:33 PM | #2 |
Rep 1,990
Instruction on what? How to install it? It slides over the roll hoops and has 4 metal hooks on adjustable straps which slip under the plastic lip below the roll hoops. Pretty self explanatory if you try it.
06-03-2010, 07:23 AM | #3 | |
Rep 145
I have the instructions somewhere, but it is really this simple. |
06-03-2010, 09:02 AM | #4 |
Rep 139
The plastic lip where the softtop folds in right ? I was looking to install it while the top was down.. found that the top need to be half up to get it in.. I installed it yesterday and drove around with it.. it does wobble a lot 60 mph on the highway.. i prob need to tighten the straps some more.. if you have the instructions i would like to see it... if possible.. thanks
06-04-2010, 06:46 AM | #5 |
Rep 1,990
Sounds like you figured it out, but I think if you tighten the straps a little more the movement will resolve. When I had one it was rock solid. Someone will probably come up with the instructions I bet. Also try bimmerfest.com
06-04-2010, 08:11 AM | #6 |
Rep 139
Mine only came with 2 strap on each side, there was 3 loop holes on each side.. can you guys confirm if its 2 or 3 straps on each side.. One side was riding up after driving for 30 min but i guess if its two, ill re-adjust it... thanks again
