      03-17-2014, 12:57 PM   #45
M Theory
Drives: E46 M3
I did arms in the back for adjustment.
      03-17-2014, 01:40 PM   #46
R0ME0
"The Midas Touch"
R0ME0's Avatar
521
Drives: F87 LBB ///M2
2017 M2  [10.00]
2008 Z4M - SOLD  [0.00]
What arms did you go with? I'm seeing online generic cheaper ones and the Rogue Engineering ones that look super beefy but are a pretty penny as well. Hoping to find a good medium alternative!
      03-24-2014, 08:42 AM   #47
p1nk50ck
HNIC
Drives: Z4M Coupe
Originally Posted by PLCZ4M View Post
Have some one got the 500 for a Roadster with costume springs? When I ask Fortune witch set up I should go for they told me the stock one is the best choice? Should I just go for the stock or get customize springs? Roaster Daily car, few track days 4-6 times during summer months.
your post is hard to understand. are you saying the stock spring rates were what were recommended, or stock springs? there's 2 different things. spring rates are customized to what you want. they have a factory equivalent spring rate, which is probably what you think "stock" is. for an additional charge, you can upgrade to swift springs, and customize those spring rates as well.
i just installed mine this weekend (coupe). i went with stock 10k springs up front and stock 12k springs in the back, and it's very comfortable, but stiff. i'm really happy with the ride quality. it feels better than most coilovers i've ridden in the past.
      03-24-2014, 10:47 AM   #48
PLCZ4MC
Proud E86M Owner
PLCZ4MC's Avatar
Yea that is what I'm trying to say for Roadster owners. yours is 10k front and 12k rear. This is what they told me "Thank you for that information! Based on your usage and setup I would recommend our 500 series coilovers with 8k front and 10k rear spring rates." thats 2k less front and back that they recommend me compare to your costume ones. I'm curious to know if roadster owners got the 8k,10k spring rates or higher for a daily car with few track days in summer.
2007 Z4///M Coupe Monaco Blue (Weekend + Track)
2018 S1000RR San Marino Blue Wrap (Weekend + Commute)
2016 Honda CR-Z EX Jet Black (Daily Commute)
2008 Kawasaki ZX6R Plasma Blue (SOLD)
2008 Z4///M Roadster Space Gray (SOLD)
      03-24-2014, 11:05 AM   #49
p1nk50ck
HNIC
Drives: Z4M Coupe
i don't track my car. but i do prefer a stiff/firm ride, and i was planning on lowering my car quite a bit, so i wanted something stiffer that would have less of a chance of bottoming out.
8k in the front and 10k in the rear is what is recommended for the e85/e86 z4m platform. it's all about what YOU want. 8k and 10k will probably give you a very close to z4m stock suspension feel. however, i went 2k more for front and back, and i still feel like it's a very comfortable ride. i'm very happy with the way it all turned out.
http://www.fortune-auto.com/fortune5...scoilovers.htm
      03-24-2014, 03:03 PM   #50
R0ME0
"The Midas Touch"
R0ME0's Avatar
521
2017 M2  [10.00]
Originally Posted by E8SEHHX View Post
You can call VEX Motorsports in San Jose, CA and ask for Anthony. He helped me with my order.
Thanks again! Took your reco on these coils. I was able to get it through a vender for $1480 shipped. Can't wait to get these on!
      04-22-2014, 11:14 AM   #51
p1nk50ck
HNIC
Drives: Z4M Coupe
so just an update, the fortune 500's didn't go low enough, i'm maxed out all the way down, and i still have a little under an inch gap between my tire and my fender (with a 5 mm spacer on the stock wheel).
However, after a short conversation with the guys over at fortune, they sent me over a set of "e36 m3 super low" bottom mounts, which should solve the problem.
      04-22-2014, 11:20 AM   #52
Beedub
send a pic of how it currently sits please, sounds plenty low enough already tbh...
      04-22-2014, 11:38 AM   #53
R0ME0
"The Midas Touch"
R0ME0's Avatar
521
2017 M2  [10.00]
Has anyone else had this issue? I'm on 19's on a 35 series tire and i want the fender to sit a tad below the top of the tire with no gap. Did they charge you extra for the bottom mounts?
      04-22-2014, 11:56 AM   #54
p1nk50ck
HNIC
Drives: Z4M Coupe
they did, it was 100 plus shipping for the bottom mounts + swaybar endlink connectors.
however, i do place a bit of this on myself, since they asked if i wanted to be super low, which i said i didn't want to be all stanced out. however, after i was done, i wasn't really happy with the drop.
      04-22-2014, 12:01 PM   #55
p1nk50ck
HNIC
Drives: Z4M Coupe
Sorry for the bad pic.
Not thrilled with how it looks right now, so not taking many:
      04-22-2014, 12:17 PM   #56
R0ME0
"The Midas Touch"
R0ME0's Avatar
521
2017 M2  [10.00]
Where did you order from? I wasn't given this option when I ordered mine. That drop looks very conservative like an 1 inch all around. I'm surprised? I heard that these coils can drop pretty low compared to H&R coils.
      04-23-2014, 08:28 AM   #57
p1nk50ck
HNIC
Drives: Z4M Coupe
I ordered from Martin Motorsports, who is a local bmw shop that is a certified fortune auto dealer. the backs can still go down a little bit more, but the fronts are pretty much down all the way. i backed off about a 1/4 inch so that it's not fully bottomed out.
i'm going to be redoing the suspension install with the new lower brackets today, along with adjustable front swaybar endlinks, and readjusting the back when i get home from work.
      04-23-2014, 10:13 PM   #58
p1nk50ck
HNIC
Drives: Z4M Coupe
Well, I guess the new brackets worked out pretty well!
      04-30-2014, 03:27 PM   #59
R0ME0
"The Midas Touch"
R0ME0's Avatar
521
2017 M2  [10.00]
Just got my Fortune Auto Series 500's today. These things look great! I got the 9k/11k combo with upgraded radial bearing and springs. Looks like I have the standard mounts not the short ones as p1nk50ck has mentioned. Has anyone had issues not being able to be "low" enough on 19's? Going to install these this weekend, hoping I wont have the issue of needing a different bottom mount.
      04-30-2014, 03:46 PM   #60
R0ME0
"The Midas Touch"
R0ME0's Avatar
521
2017 M2  [10.00]
Also did anyone get Dyno shock test printouts with their coils?
      05-01-2014, 09:19 AM   #61
DRedman45
DRedman45's Avatar
35
Drives: E86 //M coupe
I'm kinda shocked that fortune is still selling their coils with the wrong mounts. When I physically went there to have them sort out their issues, they admitted their standard springs are too tall with the standard lower mounts...you need either shorter swift springs(my set up) or the broadway static lower mounts...this was about a year ago they discovered this
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread
      05-01-2014, 11:30 AM   #62
p1nk50ck
HNIC
Drives: Z4M Coupe
no, i forgot to ask.
however, these coilovers feel great. I absolutely love the ride. very firm, but not jarring. cornering is predictable. riding on rough and bumpy surfaces doesn't feel uncomfortable.
I think if you properly set the pre-load on your springs, and have them lowered as much as they can go, you'll have a decent drop on 19's depending on your camber, tire setup, and wheel offset/spacing.
      05-02-2014, 02:05 AM   #63
p1nk50ck
HNIC
Drives: Z4M Coupe
Better pic:
      05-07-2014, 04:15 PM   #64
R0ME0
"The Midas Touch"
R0ME0's Avatar
521
2017 M2  [10.00]
Got just about everything installed. The rear springs are in just need to get the shock in and we're set. Is it just me but I found the design of the fortune auto coilover rears to be not the best. The shock I was told is adjustable to set preload on the spring (I was advised to preload by 1/8th of an inch) and the spring with the adjuster cup (spring on top and the adjuster cup on the bottom) is to adjust for ride height. The control arm shape has a dip in the center so its actually impossible to adjust the height of the car with the spanner wrenches without taking that piece out every time to adjust. I know on the KWs this is opposite that the cup sits on top and spring is on the bottom so its easy to get to. Is this just me or is this design quite odd?
      05-15-2014, 10:14 AM   #65
Platinum Child
Platinum Child's Avatar
128
Drives: Tiag z4mc
You can put the adjusters on the top or bottom in the rear, doesnt make a difference, but it also takes only a few minutes to drop the arm to take the spring and adjuster out to make a precise adjustment
IG - @sd262
      05-15-2014, 01:13 PM   #66
p1nk50ck
HNIC
Drives: Z4M Coupe
is that little bump thingy up top threaded? how do you keep the perch in place up there?
