      09-07-2011, 05:50 PM   #1
squadz
Drives: 2014 BMW 335i xDrive M Sport
Quick question..CCC or CIC?
Owner of a 2008 BMW Z4 3.0i. How do I know if it's a CCC or CIC?
To be honest, I have no idea what the difference is, I just need to know for the Nav discs.
      09-07-2011, 11:34 PM   #2
mdrobc13
mdrobc13's Avatar
Drives: Made in Bavaria
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
Should be CCC. CIC came with the 2009 idrive and NAV units seen in the 3series and on. Much better than CCC in my experiences. good luck.
'22 BMW M4 Comp (SSG/Black)
'16 BMW M4 (Shakir Orange/Black) - gone not forgotten
'15 BMW M3 (Black/Black) - gone not forgotten
'10 BMW X5M (Black/Black) - gone not forgotten
'08 BMW M3 (Space Gray/Black) - gone not forgotten
      09-07-2011, 11:46 PM   #3
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
Are you taking about the MKIV nav?
      09-08-2011, 08:06 AM   #4
squadz
Yup, that's what I have.
Just found out it doesn't play DVD's and now I'm sad. False advertising to write DVD on the drive
      09-08-2011, 08:08 AM   #5
v3.0si
v3.0si's Avatar
Drives: '08 Z4C 3.0si
neither... it's equipped with "I-Bus DVD High"
NAV DVD PN --> 65 90 2 199 841
CCC has the nav drive installed in the dash below the stereo
CIC does not use DVD's at all. they are updated through coding @ BMW only.
      09-08-2011, 09:15 AM   #6
squadz
Thanks! That helps for finding out which discs I need, perfect.
      09-08-2011, 11:18 AM   #7
psygnosis
psygnosis's Avatar
23
CCC and CIC is all iDrive which the e85/e86 cars never had, the Z4 had the same nav setup the entire run, and as far as I know the Z4 was the last car from BMW to come with the MKIV nav., maybe the last one with iBus?
      09-08-2011, 07:21 PM   #8
squadz
Two new questions (sorry I'm new and couldn't find the answer to either).
1. In the attachment, I have another button similar to button 1 above that compartment, what does it do? I push it and nothing happens?
2. I need to get my Bluetooth code, which is apparently on the TCU. I've tried opening the trunk and I'm lost at that point. Is there a step by step way getting to the TCU? Layman's guide? I want to pair my phone Ontario driving rules are strict with cell phones in hand while driving.
Any help is appreciated!
      09-08-2011, 09:19 PM   #9
psygnosis
psygnosis's Avatar
23
The button thing above the storage compartment is to manually unlatch the softtop, I'm pretty sure on 2006+ cars they removed that annoying squeaking latch and it now does nothing.
