09-06-2011, 08:56 AM | #1 |
Rep 102
Shifter vibration..odd
I have noticed that the shifter in the M Coupe has a loud vibration in 3rd and 4th under hard acceleration and high RPM's 5.5K and over. It hasn't made this noise before and it seems kind of odd. Any thoughts on what may be the cause. I have another track day coming up on the 20th and I'm hoping it is nothing serious.
Thanks!
"The best way of making a car faster is to tighten the nut behind the wheel" |
09-06-2011, 09:21 AM | #2 |
Rep 12,565
I have this same problem. Although I did install a SSK a few months back, this problem only started as of recently. And what’s most annoying is that it makes this constant buzzing noise. The second I place my finger on top of the knob (stopping the vibration), the buzzing goes away. One thing that helps (and this may be the issue) is that if I turn the knob to the left, the vibration stops for the most part. This leads me to believe the knob has developed some play and is no longer a tight fit.
Here’s a vid demonstrating it: |
09-06-2011, 07:05 PM | #3 |
Rep 102
yea mine sounds just like that. just only under hard acceleration. Not sure What it is?
09-06-2011, 07:48 PM | #4 |
Bad Lieutenant
233
Rep 3,517
For me, it was the luminated plate on top, I just had to put some more rubber cement under it to keep it quiet, although my rattle/buzz happened in all the gears.
09-07-2011, 09:39 AM | #6 |
Rep 784
Drives: 2011.5 E90 M3
Do you all have either SSKs or upgraded trans mounts? That may be the issue.
09-07-2011, 11:06 AM | #7 |
Rep 159
Mine is completely stock and was vibrating as described around 30k miles. Had the knob replaced under warranty and vibration is gone. Was definitely a loose piece at the top of the knob associated with lighting
09-07-2011, 11:17 AM | #8 | ||
Rep 12,565
I'm going to try this as well, did you pull the luminated plate off and reapply? Before applying the glue, did it actually feel loose b/c mine appears to be fine. |
09-07-2011, 12:21 PM | #9 |
Bad Lieutenant
233
Rep 3,517
It wasn't falling off, but it lifted up easily with a toothpick. I used clear rubber cement so nothing like krazy glue or anything permanent in case that wasn't the cause.
09-07-2011, 12:36 PM | #10 |
Rep 11,667
I had this in a very minor way on my previous M Roadster (ZHP knob & OE mounts & no SSK)
I noticed the same thing for the first time this weekend with my M coupe (ZHP knob & UUC black mounts & Autosolution SSK) I just lightly touch the plate on top & it stops. IMO its a knob quality control issue easily solved as "thekurgan" mentions
09-07-2011, 01:03 PM | #11 |
Rep 102
Interesting thoughts. Mine is 100% stock no trans mounts or ssk. No ZHP knob either. I will take a look at the knob and see it that's the source of the issue. My first worry was trans mounts being loose or something.
Thanks all. I'll keep you posted on what I find out
09-07-2011, 02:07 PM | #12 | |
Rep 12,565
09-07-2011, 02:17 PM | #13 |
1821
Rep 5,337
It's one of two things. Either one of the retaining clips inside the knob is broken or the glue holding the emblem has worn off. Otherwise a stock (or even aftermarket shifter) on the Z4 should be whisper quiet when in gear.
Not an uncommon thing. Replacing the knob will resolve 99.95% of "shifter noise" issues I've seen.
09-07-2011, 02:22 PM | #14 | |
Rep 12,565
