11-13-2015, 01:09 PM | #1 |
Rep 904
Parking roadster outside for the winter
I'm thinking as long as I take adequate measures to winter-proof the car, there should be no damage done to it right? e.g. park it on a tarp on my driveway, breathable car cover, gummi pfledge all seals, dryer sheets, clear snow off the car cover every time it snows, etc. Someone posted this so I know it has been done:
http://www.bimmerfest.com/forums/att...8&d=1424628381 I have space in my garage, but it'd be nice to reclaim that garage space so I can work on wood projects during the winter. What do you guys think? |
11-14-2015, 09:23 PM | #4 |
Rep 904
I'm in the Boston area, about 25 miles from the ocean. We salt heavily here, but why does it matter if the car is wrapped up on my driveway? I was debating on and off whether to drive it in the winter, but decided against it. Now debating whether to store it outside or inside. Cars tend to start seeing undercarriage rust after 6 years on the road here due to the winter salt.
11-14-2015, 09:29 PM | #5 |
Rep 11,667
You should be OK if you protect it well.
I would use heavy plastic under the car rather than a tarp, to keep moisture from coming up under the car. You want to have a tight fitting cover so that it dosnt chafe the paint when it gets windy.
11-15-2015, 03:02 AM | #6 |
Rep 876
Having the car stand outside you shouldn't use a breathing car cover, moisture will get under the car cover. Garage the car and build a bigger garage next year so you can do your wood work.
11-15-2015, 10:31 AM | #7 |
Rep 1,134
Drives: '07 M Roadster
Car covers generally aren't meant to be used outside. Yea it will protect it from the elements but even the softest cover will scratch and rub down the paint when the wind blows.
11-15-2015, 12:19 PM | #8 |
#dubspec
6336
Rep 5,201
i would pay to store it somewhere...
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
11-15-2015, 12:49 PM | #9 |
Rep 413
Drives: Z4 3.0, CLS63 AMG
Sounds like you've covered what's needed for outdoor storage, but I have to echo the post above... Anyone you know with an empty garage space or someone who lives out in the sticks with a barn somewhere, carport, etc...?
2005 BMW Z4 Roadster 3.0 - Black Sapphire with Red Extended Leather / NAV / Premium & Sport Pkgs / 19" wheels / M steering wheel / Xenon
2013 Mercedes CLS63 AMG |
11-15-2015, 03:55 PM | #10 | |
Rep 4,057
I am much closer to the ocean so in winter we can get wet weather off the ocean and it can tend to be salty which is not good for your car as you know. If the city there uses lots of road salt your winter car will carry it into your driveway, so if you can park the car away from the driveway (behind the house maybe) then that will reduce the chance of salt getting at the car. As others have said if you keep her outside, seal her up good! |
11-19-2015, 11:05 AM | #11 |
Rep 71
I got my car last fall and covered it outside during the winter with the OEM cover. Lots of snow last year in the mid atlantic. Everything turned out fine. The only advice (based on my mechanic) is try to drive it around if you can. Obviously I would avoid the slick/salty days.
on a side note, does any know how to clean the car cover. Will a dry cleaner take care of it? I'm kind of worried of the chemicals they would use transferring or having an affect on the paint. |
11-20-2015, 08:54 AM | #12 |
Rep 2,665
If given the option of either parking the car outside all Winter or having it in the garage, starting it and backing it out to do projects in the garage I would park it in the garage and back it up occasionally. 25 miles from the ocean in Boston seems like a pretty harsh environment to me. Also, the tiny amount of wear that comes from the start isn't nearly as hard on the overall car as leaving it outside with a cover on and under it. My daily driver (never in a garage) often doesn't get started for 5 days in a row (work out of my house and travel) and I have never had a problem with it's engine or the previous cars engine (sold it at 153k miles).
11-23-2015, 02:12 PM | #13 |
Rep 779
I would say dont do it.
I left mine out 2 years ago in my back yard. Had 11" of snow on it for 2-3 months. After it melt away, the famous convertible motor had died. If you really have no choice figure out how to make sure water doesnt collect on the convertible top.. I had a cover on mine but I notice moisture was frozen directly on to the car. Meaning I can't pull the cover off without risking some damage. I usually garage the car in the winter but missed it that year.
-Roranji
11-24-2015, 07:35 AM | #14 |
Seasoned Novice
Rep 54
I second what David wrote - keep inside and back out temporarily. If you have a cover you could even leave it out overnight to get snowed on - still better than long term in the weather.
.HanK.D.KranK. <<<<<<<<<< |
11-24-2015, 07:58 AM | #15 | |
Rep 904
This is what I've decided to do. Now I just need to find a garage heater to keep warm while working. |
11-24-2015, 01:32 PM | #16 | |
Rep 11,667
On a couple of occasions when I had to do this, I pushed it out & back in w/o starting.
11-24-2015, 02:08 PM | #17 |
Rep 904
Thanks. I may just push it out and then start the engine to bring it back in. I've already tried pushing it into my garage without success because of the slight incline I have.
11-24-2015, 02:39 PM | #18 |
Seasoned Novice
Rep 54
Sitting outside idling in the winter may not get the exhaust hot enough to burn off the condensation. I say run it as little as possible until you can take it out and drive it.
11-30-2015, 08:23 AM | #19 |
Rep 2,665
I would probably push it out and drive it in, also not getting it up to operating temperature, but this is a guess on which way is better. Pushing it out only if relatively easy.
I don't see condensation in the exhaust mattering much anymore as I don't believe there is anything to rust (all stainless).
11-30-2015, 09:13 AM | #20 |
Rep 4,057
If you simply start the engine, immediately slap her in gear, drive ten feet to get out of the garage, and immediately turn the car off - and the same to get back in a few hours later - would that be a problem in your view? I'm thinking this could be as short as 30 seconds run time or less.
Huz-Z
11-30-2015, 09:39 AM | #21 |
Rep 11,667
hard to really say for sure, since you cant see what the result is.
I guess the question is will the internals be warm enough to cause internal condensation as it cools. I'm in the middle of renovating & heating my shop (& car storage) Next week I have to move the car from one bay to one of the others temporarily, & back when complete. I will definitely be pushing it. For me its not a big deal as my drive is fairly level.
11-30-2015, 10:32 AM | #22 |
Rep 4,057
When in doubt, better safe than sorry!
Huz-Z
