      09-12-2018, 05:46 PM   #1
bmwclubracer
Drives: Z4
2007 Si, oil light stays on after car is shut off.
Do I have anything to be concerned about? I drive this car seldom but when I do I get on it a little bit, after engine is warm of course. I can't find a dipstick so I'm wondering if I've got a problem. Car runs perfect and owners manual didn't help.
The light remaining on is intermittent, or maybe it's always done that and I just never noticed until now.
      09-13-2018, 02:05 PM   #2
Roadroach
Roadroach's Avatar
165
Drives: 2006 Z4 3.0si coupe w/stick
With the 3.0si, you don't have a traditional dipstick.
There are two buttons at the base of the instrument cluster (just above the steering column). After the engine is warm and the car is on level ground, push the right hand button. It'll indicate the oil level in the display under the speedometer.
Maybe the light is coming on intermittently because you're low on oil?
2006 Z4 coupe - with HOMELINK!
1966 Mustang GT fastback (too many mods to list)
2015 335i GT
2014 981 Cayman S manual
      09-13-2018, 04:16 PM   #3
garz747
Drives: 07 Z4MC 01 330i 18 X3 M40i
What in gods name was wrong with a traditional dipstick? I fail to see how BMW in their infinite wisdom has eliminated these. My friends 328 had a similar problem and it was the electronic oil sensor at fault.
      09-13-2018, 04:24 PM   #4
Roadroach
Roadroach's Avatar
165
Who knows. Freaked me out the first time I went to check the oil and couldn't find the damn thing myself.
2015 335i GT
      09-13-2018, 04:42 PM   #5
gpraceman
gpraceman's Avatar
Drives: '06 Z4 ///M Roadster
I'm glad my '06 Z4MR has the old fashioned dipstick.
2006 Z4 ///M, Interlagos Blue/Beige
2006 Z4M Interlagos Blue/Beige
      09-13-2018, 06:33 PM   #6
StickMon
StickMon's Avatar
Drives: 2006 MR
Well, if you have an ///M, the plastic tip falls off.
And there's an aftermarket one with a metal tip, that may or may not fall off, but it's too short.
      09-14-2018, 05:04 AM   #7
bmwclubracer
Drives: Z4
Thanks for the info, I checked and the little graphic showed it's full. And I didn't notice the oil light after shut off so I guess I don't have to worry about it.
I don't like not having a dipstick. I've stayed away from newer BMWs primarily because of all the electronics package (I don't like the joystick or whatever it is) and I like to check my own oil.
