      08-17-2018, 03:07 PM   #1
Epwebb64
Drives: 07 Z4M Coupe
Trickle charger hook up
Can I hook up a trickle charger to my positive jump post under the hood or does it have to be hooked directly to the battery? Sorry for the stupid question guys I've never used one before.
      08-17-2018, 03:32 PM   #2
rockstar93
rockstar93's Avatar
Drives: E86 Z4MC; E92 M3
You can hook it up to the positive post under the hood. I put the negative on the nut/bolt on the firewall braces and am able to run the cable to the headlight. Because of this you can fully close the hood with the car charging and also not have it hanging against your paint.
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE
E90 M3 Sedan 6MT Jerez Black/Fox Red GONE
E86 Z4M Coupe Interlagos Blue/Black
E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread
DEG67.50
      08-17-2018, 04:40 PM   #3
Epwebb64
Great idea. Thanks!
      08-17-2018, 05:10 PM   #4
DEG
DEG's Avatar
68
Drives: 2007 Z4 MR
I do exactly what rockstar93 does.
      08-18-2018, 09:48 AM   #5
bobhnc
Drives: 2007 M coupe
You can also plug it into the cigarette lighter (you need to get an inexpensive adapter). I lower one of the windows an inch for the wire. Very quick and easy.
      08-18-2018, 09:08 PM   #6
gpraceman
gpraceman's Avatar
Drives: '06 Z4 ///M Roadster
I've hooked to the terminals under the hood and to the cigarette lighter. Unless I have it bedded down for the winter, I use the cigarette lighter if I will not be driving it for a bit. That is so I don't drive off accidentally with the charger connected to the car.
2006 Z4 ///M, Interlagos Blue/Beige
2006 Z4M Interlagos Blue/Beige
      08-19-2018, 11:02 AM   #7
bosstones
Drives: o_0
I've always gone about it the same way rockstar does (incl the routing). Never had an issue.
      08-20-2018, 10:36 AM   #8
ShakyDog
ShakyDog's Avatar
Drives: 2007 Z4 3.0i Alpine White/Red
I put mine direct on the battery and then just close the trunk on the cable, it does not cause any issues to anything as the rear gasket is very soft and does not pinch the cable.
Steve
      08-20-2018, 12:22 PM   #9
Huz-Z
Huz-Z's Avatar
Steve
I've been doing the same for years now for winter storage - and during summer, if I figure the car will be parked for more than a week or so.
Huz-Z
      08-20-2018, 01:27 PM   #10
Steeler
Steeler's Avatar
2429
Same here.
I do drape a soft rag over the bumper cover where the cables sit so any possible rubbing doesn't hurt the finish.
      09-04-2018, 05:33 PM   #11
1Joel1
Drives: 2007 M Coupe, 2010 335d
Directly to the battery with the Battery Tender plug exposed. I then close the trunk on the cable located at the slight indent and there have been no issues at all.
Joel
