      08-24-2018, 11:01 AM   #1
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Grinding noises after installing X-pipe
I've recently installed the RE X-pipe and is loving the extra volume. However, I'm getting a rubbing noise, almost like 2 things are grinding, intermittently while going on somewhat smooth surfaces. This appeared to only happens after the car is hot. I don't hear anything when going over rough patches. I had tried shaking the exhaust cans themselves and they are solid - no rattles. Other than the heatshield potentially rubbing on the driveshaft (is this even possible), does anyone else have any ideas what else could cause things to rub when installing an X-pipe? Any inputs would greatly be appreciated. Thanks.
      08-25-2018, 05:18 PM   #2
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
As it turned out, it was a relatively simple fix. The installer used a screw on the x pipe mounting plate that was too long and was hitting the plate or heat shield above it. Swap out for a shorter screw and problem solved...at least I hope problem solved - I haven't heard any noises on the drive home. I love simple fixes
Finnegan703.00
      08-25-2018, 08:16 PM   #3
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
YAY!!!!
So pleased to hear this; it wasn't a RE QC issue....it wasn't a fitment issue....great news.
Racerbruce
      08-28-2018, 10:39 AM   #4
3002 tii
3002 tii's Avatar
2285
What’s your overall exhaust setup? I just want a little extra grunt out of my factory system but don’t want to introduce drone neither. Was thinking maybe the RE X pipe was the answer...
Follow for latest mods
      08-28-2018, 12:06 PM   #5
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Just the RE X-pipe with Eisenmann sport cans. Everything else is bone stock
You know, after looking at the stock x-pipe off the car, you can just have a shop cut that resonator off and replace with a couple of pipes and saves some cash. The stock piece already have the crossover built-in.
      08-29-2018, 01:32 PM   #6
RossBMWZseries
Is it true that the OE X pipe has a bigger diameter than the RE X pipe? Cutting out the resonator may seem like a good cheap idea instead of paying the ~$600. I just wouldn't want the little (if any) performance gain affected by a local shop modifying the OE X pipe
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
1998 BMW Z3 Roadster 1.9L E36 SOLD
      08-29-2018, 04:16 PM   #7
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
If the OE X pipe has larger diameters, then I couldn't tell. Both OE and RE pipes mate straight up to the OE S pipes without any expansion or necking down. The only thing that I had noticed is that the OE pipes are rectangular/squarish in shape after the resonator.
      08-30-2018, 01:36 PM   #8
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
I run RE X-pipe and cans. Personal opinion, if I were to do it again, I would skip the X-pipe. Would def do headers first and foremost and then cans for some extra noise.
The Raspinator
      08-30-2018, 01:45 PM   #9
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Unfortunately, I live in the Republic state of California - I can't and don't want to touch anything emission related, which means nothing forward of the X-Pipe. Heck, I can't even touch the intake for that matter
At this point, I'm pretty happy with the sound and the car and is pretty much done "modifying" it - famous last words. Although I may consider a suspension refresh sometimes down the road, but that is about it
      09-02-2018, 02:36 PM   #10
StickMon
StickMon's Avatar
Drives: 2006 MR
I manage to get away with RE catless S-pipes.
I take it somewhere where I know they won't bother looking under the car.
      09-02-2018, 07:28 PM   #11
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
That had crossed my mind, but I really don't like the off-chance that a different tech would end up checking for it and failing me. At this time, I'm not really itching for a set of catless S-pipes - yet.
      09-04-2018, 04:53 PM   #12
RossBMWZseries
That's right, yet....
I'm so tempted to run to my local muffler shop so they can cut out the resonator off the OE X pipe. I wonder if my car would spit out flames with my catless headers, 100 cell race cats in the S pipe, and RPI mufflers
