      03-05-2014, 03:59 PM   #1
z4msteve
Drives: '07 Z4MC
265/35 square on OEM Rears (Pics)
4x OEM rear wheels on OEM suspension, front camber at ~3.2ish using only camber bolts. ( http://www.turnermotorsport.com/p-42...otorsport.aspx ) Tires are 265/35r18 Nitto NT05.
Some fitment pics.
View post on imgur.com
(From above)
RPI scoop, Euro headers, SS PowerLoop, Epic race tune, AKG motor/trans mounts, Turner camber bolts
      03-06-2014, 12:26 AM   #2
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
Looks pretty good!
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights
      03-06-2014, 12:54 AM   #3
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
nice! this is a first!
      03-06-2014, 04:00 AM   #4
z4msteve
Drives: '07 Z4MC
With as cheap as these wheels can be found for on here, this ended up being the most "cost effective" way to get a square setup for the track. Granted these are pretty heavy wheels but until I can get something else these work fine.
      03-06-2014, 01:17 PM   #5
Barryb97
Drives: 2006 M coupe
Have you had it on the track yet? If so, how did it feel? Any rubbing?
CDV delete, clutch stop, BMW pedals, Strongstrut bar, CF rad & coil cover, M3 reps, roundel under hood, Intravee II, air bag sticker delete, first aid storage, painted reflectors, headlight washer disable, Skyer CF front lip, Short shift kit, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings, TC Kline DA coilovers, PB big brake kit, Skyer CF rear spoiler and diffuser, oil pressure and water temp guages.
      03-06-2014, 02:15 PM   #6
z4msteve
Drives: '07 Z4MC
Going out on Sunday so I'll let you know what I run into. Hoping for a big improvement over the tiny original front tire size.
      03-07-2014, 07:50 AM   #7
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
Looking forward to your impressions as this is exactly the question i asked a while ago and got no firm reply.
      03-10-2014, 10:31 AM   #8
z4msteve
Drives: '07 Z4MC
Impressions from the weekend were very positive.
No rubbing that I could notice. (stock suspension, only using the camber bolts as mentioned above.)
Threshold breaking felt much more solid/confident with the additional rubber on the front.
Entry felt much improved. Perhaps a little more need to use power to finish rotating but only felt this on a couple of slower corners.
I've read that some feel going with the wider wheels/tires in the front reduced road/steering feel but this wasn't the case from what I could tell. A quality alignment definitely helps here.
Of course, these are just my impressions and I'm no pro driver so YMMV. Having said that, I personally won't be going back to the smaller fronts any time soon.
      03-10-2014, 10:34 AM   #9
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
Sounds like a result then! Do the NT05's run wider than "normal" tires of the same width?
      03-10-2014, 10:40 AM   #10
z4msteve
Drives: '07 Z4MC
That I couldn't answer, you'd have to do some digging that I didn't bother with. I sort of just ordered them and hoped they would fit.
      03-10-2014, 10:41 AM   #11
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
No problem, just wondered if you knew
