12-27-2012, 12:00 PM | #1 |
Rep 250
What spacers with OEM wheels
What would be the recommended spacers to push OEM wheels to the outer corners, nice and flush.
OEM springs 245/40/18 265/40/18 -2.5 camber Thanks. |
12-27-2012, 03:28 PM | #3 |
Rep 11,667
I think I used 12.5 with OE.
12-27-2012, 08:00 PM | #4 |
M = Midlife Crisis
65
Rep 2,006
Depends on tires. With 235/265 Dunlops the fronts were good however I had slight rub on the rears with 12.5mm. I was lowered ~ 1/2". With OE tires they are fine. Punko I have 4 - 12.5mm Turner spacers if you want to try them?
2006 Z4MC - #LL93158
12-27-2012, 09:21 PM | #5 |
Rep 12,565
For front, rule of thumb is to avoid 10mm spacers since hub lips vary. If it were me, I'd go 5 or smaller, or 12 or bigger on the fronts to avoid any issues. For the rears, any size works
15's would be flush to slight poke. 12's on all 4 corners should be flush without too much risk of curbing. Either way, make sure to get longer bolts. |
12-28-2012, 05:19 PM | #6 |
Rep 1,031
I am running 12.5 in the front with the OE sizes. You are welcome to try the set I have on too if we meet up. I have more (less, i dont know) camber. On sharp bumps I rub a little bit. Then again I am lowered slightly as well.
If you want a set of 12.5mm I have brand new from Turner I haven't opened and not sure if I will use. Caddy looks like he has a few sets kicking around too. lol |
12-30-2012, 08:03 AM | #7 |
Rep 347
Drives: 2006 BMW M COUPE
Do the spacers affect handling or additional stress on the wheel studs. I considered putting the tires "out there" a bit , however with the shit on the roads these days all I would end up doing is sand blasting my paint
12-30-2012, 06:31 PM | #8 | |
6 of Diamonds (ret)
82
Rep 566
2007 Z4Si(gone)
Couple E30 Verts (DD) 2003 330i 2011 E93 335is - current fav |
