      06-01-2015, 12:32 AM   #1
Juggernaught5
Drives: 2006 BMW Z4 3.0si Roadster
Ventilation system: vent selection issue
Hi All:
I'm having an intermittent issue with the ventilation system. I always have the vent selection choice set to the dash vents. Occasionally, after starting the car, the air will start blowing, but out of the windshield vents (with the selector knob still on the dash vents). To correct this, I have to cycle through the vent choices until the dash vents "kick in." There's no issue with fan speed or air temp - just the vent selection.
Of note, I have noticed a chunk of foam-like material in my driver's side vent above the cup holder. I tried to pry it out, but it breaks down. It's about 1/2 square.
Can anyone help me diagnose?
      06-01-2015, 10:59 AM   #2
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
When you notice the air coming out of the windshield vents, is the HVAC in "Auto" mode? Either you are putting it in Auto mode and not remembering/realizing, or perhaps it is going into Auto mode by itself and you have a buggy HVAC control.
      06-01-2015, 02:57 PM   #3
Juggernaught5
I don't use auto mode too much, and right now occurrence varies. When I start the car, the air will come on, then switch from only the dash vents to only the windshield vents, with the rotary knob never being moved and still on the dash vent setting.
      06-04-2015, 10:04 AM   #4
Incompatible
Drives: 07 AW Z4C 3.0Si
Maybe related to your issue: I've always used mine on manual and once in a great while the change over from one vent to another is slow. My guess is the diverter plate (gate) or linkage is a little sticky. All I do is to cycle through all the vents with the fan on high a couple of times and the problem is solved for 12-18 months. Being in SoCal, rarely do I change any of the controls and suspect the lack of use is a contributing problem. It has done this since new (single owner) and has stayed the same over the years.
I wonder if the foam seal is/was limiting full positioning of the gate and somehow the electronics are going to a default setting?
      06-04-2015, 05:52 PM   #5
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
Possibly another related issue I've been having since I got the car. I can select just the dash and I can select just the floor and it will work fine. If I try to go to the middle of these two I get dash and windshield every time.
      06-04-2015, 06:59 PM   #6
TommyA
Drives: 2007 Z4 3.0i
I have noticed that there was a piece of insulation in the vent on the driver side as well. I just stick something small enough to try and break it up so it will blow out of the vent, I don't think there is anything to worry about.
      06-05-2015, 01:10 PM   #7
WAMz4
WAMz4's Avatar
Drives: 2006 Z4 3.0si Roady
Must just be the car.
I always leave the vents set to dash vents, sometimes when I first get in, the fan is blowing at the set level but air from vents is low, as if it were re-directed. I have to move the vent slector to a different region and wait for it to blow full, then move back to dash selection to get full air flow back to dash.
