06-03-2015, 04:37 PM | #1 |
Rep 2,704
Dissimilar Metals
In particular alloy rims and steel rotor hats.
How do you guys prevent the alloy rims from corroding themselves onto the steel hubs? When I first got my car and changed out the wheels I had to literally beat the wheels off the hubs with a sledge hammer from behind. I resorted to applying a little bit of never sieze paste to the new wheels but it makes a mess. I am due for brakes and so was thinking about making a "gasket" from thin rubber or even thin gasket paper to go between the rim and the hub. Comments?
06-03-2015, 04:51 PM | #2 |
636
Rep 3,124
I cleaned mine as well as I could with Brakleen and Scotch-Brite.
Then I dipped my finger in some 10W-60 and rubbed it onto the hubs. Seems to be working, but I'm in a very benign weather environment. I doubt there's enough gap on mine for a solid gasket. I'm pretty sure that's what centers the wheel, but the non-///M may be different.
06-03-2015, 05:24 PM | #3 |
1821
Rep 5,337
Anti-seize paste is one of those "a little goes a very long way" compounds. The less you use, the more effective it is.
If you're applying it and it's making a mess, then you've applied too much. Of course, I change my wheels/tires once a month due to my extra-curricular activities and my location, so there's little to no chance of them seizing to the hub.
06-03-2015, 05:56 PM | #4 |
Rep 59
+1 on the hack. a little should be all you need and probably only at the center ring.
I would strongly recommend against any kind of oiling or gasket. A major component of your wheel staying on your car is friction (clamping force) between wheel and hub. |
06-03-2015, 07:50 PM | #5 | |
Enthusiast
17
Rep 245
2016 550i M-Sport
2008 328i M-Sport (Sold) 2007 Z4M Roadster (Sold) |
06-03-2015, 09:56 PM | #7 |
Rep 1,543
Anti-seize for me, too. Works like a charm. A little does go a long way....not sure I'll ever finish the little tub/bottle I got.
- Jeff
bosstones' flickr |
06-03-2015, 11:18 PM | #9 | |
Rep 904
06-04-2015, 05:05 AM | #10 |
Rep 2,704
Not sure where to buy anti sieze.
I have an old can left over from my tool and die maker dad.
06-04-2015, 08:04 AM | #11 |
Rep 1,107
I still have the same bottle of Permatex "silver and get's all over everything) anti-sieze for the past 30 years. Stuff is great....in moderation.
06-04-2015, 10:39 AM | #12 |
#buildnotbought
10847
Rep 4,892
Never ever use a gasket from paper, rubber or whatever!
With a compressable material between the rim and hub you cant torque the bolts (the bolts won't hold the torque) and you could loose a wheel, or in your case, 4 wheels.... I use some copper grease, a very thin film applied with a brush... Especially around the centre round fitting flange.
06-04-2015, 02:20 PM | #14 |
Rep 4,057
Its common now to find these electronic modules installed on cars that create a very slight charge throughout the vehicle that makes the entire car cathodic relative to the sacrificial anode contained within the unit.
I wonder if that would suffice to prevent this from happening - and eliminate any further rust from developing or progressing elsewhere on the car? Sadly, those devices are way more pricey than the solutions above, so likely not practical.
Huz-Z
06-04-2015, 04:00 PM | #15 | |
#buildnotbought
10847
Rep 4,892
So if your car is all wet everywhere it will work but rust usually occurs on those spots that stay wet, and those are pretty well hidden. You'd have to dip the sacrificial anode in the same wet spot, and that is usually a very thin layer of water on the metal, thus short circuiting the device.... So no, that won't work. Could work on a boat though. Galvanizing the steel (usually zincplating), so that there is sacrificial material everywhere does work
06-05-2015, 06:53 AM | #16 |
Rep 4,057
Hmm. I thought that the theory is that every metal part of the car that is not insulated from the point where the device connects, has a small current and the car becomes one big cathode so that all the corrosion takes place at the sacrificial anode. But I think there are mixed reviews on how effective these systems are.
Huz-Z
06-05-2015, 07:52 AM | #17 |
Rep 2,138
Drives: Me
Its called 'Cathodic Protection' and its been in use on ships and boats for 40 years, but as GuidoK it will not work on an automobile.
There are two types of Cathodic Protection, active and passive. Passive normally just uses a zinc anode to dissolve away thus protecting the base material. Active uses electric current. |
06-05-2015, 11:49 AM | #18 | |
Rep 2,704
Thanks for all the input. I will stick with the "little dab'll do ya" process.
06-05-2015, 02:39 PM | #20 |
Rep 2,138
Drives: Me
On modern US Naval warships, they use a combination of passive and active cathodic systems. US Naval Submarines use a passive system although the new Virginia class might use an active system, but I doubt it, from a detectability standpoint.. I just never noticed when on board. I may have to look next time I am onboard a 774 class boat.
06-10-2015, 09:41 PM | #21 |
Rep 1,543
Ha! That's the same thing I have. Guess it'll be with me a while, too.
- Jeff
bosstones' flickr |
