02-27-2012, 10:28 AM | #1 |
Rep 779
Anyone tried to add usb power to that aux in panel ?
http://z4-forum.com/forum/viewtopic.php?f=31&t=19293
I want to attempt something like this but I dont need a 4 port usb hub. Also dont like to use another cig charger in the back panel.. If i grab a usb header, is there anything behind that aux-in panel that I can splice and supply power to usb ports to charge iphone, etc ?
-Roranji
02-27-2012, 02:34 PM | #3 |
Rep 779
But you would still tap off the existing cigarette lighter ? just wondering if there is enough juice to support both sides.
-Roranji
02-27-2012, 02:46 PM | #4 |
Rep 2,866
I don't understand why you would want to make it so complicated when there's a simpler solution => http://www.cellphoneshop.net/usbcar.html
02-27-2012, 03:09 PM | #5 |
Rep 4,128
Drives: M235i & G30 540i
I would want an aux outlet that can also charge while playing tunes.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
02-27-2012, 07:08 PM | #7 |
Rep 273
The cigarette lighter circuit is already fused for 15 amps - something like an new iphone is going to draw maybe a maximum of 1 more amp. You can get a pretty compact voltage converter for that kind of low amperage, if you want to keep a 'flush' appearance for another USB outlet on the lower panel.
Another option, as you've already got 2 other USB devices you want to use concurrently, is to just add a 12V powered 4 port hub like this one. It would look after all your USB requirements and get rid of the plug-in adapter you're using now. Car USB Hub |
02-27-2012, 08:41 PM | #8 |
Rep 779
sounds good..
I'm thinking of using 2 of these . All I need is 2 holes for cable to go through, screw it to that aux in plate from the front. http://www.kramerelectronics.com/pro...el.asp?pid=666 and in the back, setup something similar to the z4 post above
-Roranji
