09-07-2017, 10:15 AM | #1 |
Rep 770
Is There a Way to Refurbish a Z4M Steering Wheel?
It seems that just about every Z4M that I see has this wear on the steering wheel. Is there a way to bring it back to looking new?
09-07-2017, 10:36 AM | #2 |
Rep 679
My coupe only has 14000 miles lol- so no wear yet but ive seen others have success with fine sandpaper and black krylon spray or equivalent. Also viny wrap is worth a try. Best of luck.
09-07-2017, 11:46 AM | #3 |
Rep 4,057
Sad but true. I obsess over not dragging my hands and wedding ring across the steering wheel's spokes to avoid this. Particularly when you realize that I had my M steering wheel supplied and very capably installed at the local Canadian dealer who had no choice but to do so at Canadian (OUCH!!) prices!
Huz-Z
09-07-2017, 03:33 PM | #5 |
Rep 870
Drives: 2006 BMW Z4M Roadster
A number of folks have used Plastidip spray to provide that same rubberized texture. Pieces need to be prepped first to remove the old rubberized coating.
http://www.zpost.com/forums/showthread.php?t=425662 And this from an old Bimmerworld post: Seems the best outcome was to remove all of the old sticky black soft touch with lacquer thinner right down to the plastic. Not too hard to do. To get a perfect finish it all needs to go. Next get a can of Colorbond BMW black spray paint from Barvarian autosport. This paint will dry fast, will not fisheye, and give you a great finish. Do several light coats with 10 min. for each coat to dry. It will dry to a beautiful satin finish and look factory. I use it for any plastic on my BMW that needs refurbed. Love the quality of the finish. Colorbond BMW Black 258 is what you need. Good Luck. Salty
09-07-2017, 11:02 PM | #6 |
6 Cylinders 3 Ways
369
Rep 459
If you wanted to wrap these in a CF vinyl would you still need to strip everything down to plastic for a good result? Also interested to hear if anyone has tried hydrocoating?
09-08-2017, 01:10 AM | #7 |
Rep 202
I'm not sure if that is a coating on the plastic that just deteriorated over time or a build up of whatever was used to detail the interior. I was able to scrape off the scum with my fingernails. So, I decided to take apart the steering wheel and give those pieces a good scrub down. It took some elbow grease, but they look brand new now. Just make sure to disconnect the battery before you pull the air bag off.
2006 Z4 ///M, Interlagos Blue/Beige
09-08-2017, 10:34 AM | #10 |
Rep 3,004
My right side spoke cover was cracked, so I had all three replaced w/OEM in 2010....regrettably, they have suffered scratches from usage. I've tried topical treatments to remove the scratches, but it hasn't helped.
Racerbruce
09-08-2017, 10:35 AM | #11 |
Rep 3,004
CF
Thank you - can you provide the CF wrap info, and any details as to how you cut it to fit; did you apply and cut in place?
Racerbruce
09-09-2017, 11:36 AM | #13 |
Rep 453
Drives: 2007 Z4M Coupe
Remove, strip and repaint. I used matte black Plastikote paint. Worked out real nice. The hardest part was removing the trim. Be careful, the tabs tend to break. The tabs on my center lower trim broke but nothing gorilla glue couldn't fix
09-09-2017, 12:04 PM | #14 |
Rep 2,704
I disassembled mine and had them hydro dipped in CF look then clear coated.
Cost $150 locally Going on 2 years now. As new still
09-10-2017, 06:52 AM | #17 | |
Rep 2,704
I however did many other pieces besides that.
09-10-2017, 06:52 AM | #18 | |
Rep 2,704
09-10-2017, 11:11 AM | #20 |
Rep 2,704
NickyC17479.50 |
09-10-2017, 01:09 PM | #21 |
Rep 2,866
09-10-2017, 09:36 PM | #22 | |
Rep 209
Drives: Z4M roadster
Refurbing definitely the better option!
2006 Z4M roadster. Interlagos Blue, black extended leather with carbon trim. Apex EC7 8.5/9.5 x 18 rims, Strong Strut brace, KW V3s with RE rear shock mounts, Vibra Tech and Rogue engine/transmission mounts, Stromung exhaust, CDV delete.
