      07-05-2017, 07:39 AM   #1
acer54
Drives: Z4
CTEK Trickle Charger Lead From Cabin To Boot/Trunk
I have a CTEK charger and want to use it during the winter to keep the battery charged during the winter, I need to run the lead from the cabin to the boot/trunk, I think running it through the cubby behind and in between the seats is the best way - is this possible preferably without any drilling or cutting?
      07-05-2017, 08:29 AM   #2
3002 tii
3002 tii's Avatar
2282
Why not just run it from the hood? I have mine zip tied to the one of the strut bars leading to firewall when not in use.
Follow for latest mods
      07-05-2017, 09:29 AM   #3
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Why not just connect it directly to the battery itself if you're going to run the cable through the trunk?
Do you mind sharing a picture of how you connect up the connector to the car (positive and negative side)? Thanks.
      07-05-2017, 09:57 AM   #4
3798j
3798j's Avatar
11379
Drives: E86 3.0si
'55 Ford F100  [0.00]
'08 Z4 3.0SI  [8.50]
'66 Triumph TR4A  [0.00]
'85 Corvette  [0.00]
'64 Corvette  [0.00]
'68 Triumph GT6  [0.00]
'19 VW Golf "R ...  [0.00]
Here's how I run mine. From under the hood it exits just to the left of the driver's wiper arm.
Plus wire connected to stud underneath the positive jumper post.
Negative wire to a grounding stud on the firewall.
XMetal1131.00
      07-06-2017, 07:40 AM   #5
acer54
Drives: Z4
Installed the wiring today directly to the battery terminals (which is how I did it in my last car) will line the lead up with the plastic indents on the rear trim panel and close the lid - Sorted!
      09-16-2017, 11:57 AM   #6
Hedward
Hedward's Avatar
Drives: 2007 BMW M Roadster
I purchased the Panel Indicator Connector from CTEK and mounted it in my battery box. Works great and I like the green, yellow and red lights indicating the battery charge status.
Mirko182.00
SaltyNC369.50
