07-30-2013, 05:30 PM | #45 |
Rep 370
Drives: 2007 BMW Z4MC
Garage List 2007 BMW Z4MC - Sold [7.66]
2006 330ci ZHP [0.00] 2000 Porsche Boxster S [0.00] 1972 DeTomaso Pantera [9.50] |
Consider an Odyssey Battery, I've had very good luck with this brand. Avoid an Optima Battery.
07-30-2013, 05:33 PM | #46 |
Rep 224
Avoid Optima like the plague. When I ran my battery business, we had a disgusting amount of Optimas used as core exchanges. They no longer honor their warranties and to my knowledge, may not even be US produced anymore. Whatever it is, something happened, and their quality is piss poor nowadays. They were bought by Johnson controls in 2000 and mid-2000s their quality started to plummet...
07-31-2013, 02:30 PM | #47 | |
Rep 3
12-10-2013, 10:38 AM | #48 |
Rep 1,061
Does anyone know the part number for the expanding rivets holding the battery cover on to the battery base plate? The ones with the "screw/hex head". I can only find the blind head non-expanding variety on realoem.
12-10-2013, 10:16 PM | #49 | |
Rep 1,991
12-11-2013, 12:46 AM | #50 |
636
Rep 3,124
That's what I thought, too, but it's shown as a plug, and ECS doesn't have a picture of it.
Pull a 51168197908 out of your fan shroud and see if it fits in the battery cover.
12-11-2013, 08:46 AM | #51 |
Rep 1,061
12-11-2013, 10:04 AM | #52 |
Rep 1,991
Good work finding the real part number. Funny that it doesn't show up on the TIS. I had a similar issue trying to find the part number for the expanding rivets which hold down the curved piece which attaches at the top of the center console storage compartment.
12-11-2013, 10:06 AM | #53 | |
Rep 2,866
12-11-2013, 12:44 PM | #55 |
636
Rep 3,124
Might not be the exact same part, but if it works, it works.
I only remember having 2, on the bottom left side of the box.
12-20-2013, 10:41 AM | #56 | |
Rep 238
Please ensure that the vent tube is connected. When batteries charge, they release hydrogen gas which is EXTREMELY flammable (more so than even gasoline). The vent releases the hydrogen to the air outside of the car rather than allowing it to build up in the trunk and potentially cause an explosion. |
12-20-2013, 10:20 PM | #57 |
Rep 52
I know my limitations, and my frustration level--any troubles with battery and BMW assist is called and tow truck is on it's way. Prior to joining forum y car had dead battery once and my husband replaced battery...had lots of issues ---had to take to dealership to "reset" a/c and GSP
06-17-2017, 12:03 PM | #58 |
Rep 2
While this is an old thread I would like to thank all here for the information.
I have a 2007 Z4M roadster which I bought new. In 09 BMW replaced the battery and alternator. Last week the battery (which had been really straining) finally failed to turn the car over. The info on this thread allowed me to swap out the battery without too much trouble. The best matched battery I found was the Duracell Platinum H7 AGM (850 cca) which slid right in....when BMW replaced the battery in 09 they didn't reinstall the vent tube and I went to the dealership for the elbow, tube and three replacement screws for the compartment. BTW hooking the car to the charger kept all my presets operating while the battery was out...no problems with anything and boy does it turn over fast now! Again you folks have my thanks. Last edited by bimmerjim07; 06-17-2017 at 07:47 PM.. |
06-18-2017, 12:05 PM | #59 |
Rep 3,004
Suggest replacing batteries based upon life cycle; I replace every 4 yrs - the risk(s) associated with being stranded and requiring flat-bedding your beloved machine is not worth it.
Racerbruce
06-10-2019, 05:56 AM | #60 | |
Rep 194
Drives: 06 Z4M Roadster
Garage List 2006 Z4MR [0.00]
1972 For Sale Datsun [0.00] 2001 Dog/kayak haul ... [0.00] 2010 Daily Driver H ... [0.00] |
Thanks
* Added after doing some work on the car earlier. While going over the engine compartment ( that I thought I knew pretty well, since I've detailed it twice and done some work on ) I " discovered " I large red wire and a medium red wire going up the fire wall, sort of center/left, coming up to a small black plastic box, which has a top with a BIG "+" on it, I flipped the top up, found that there was a post. So before removing the battery which would not charge and repeatedly came up FAIL on my new charger, I attached the positive from the charger to the post, the negative to bare metal nut on a bolt that would act as the ground. I was just going on a hunch that this may be how to keep a charge going so all my preset functions would stay. When I disconnected the battery my charger went blank. So is that just for use in jump starting from another vehicle ? If anyone ever reads this and has answers I'd sure like to know, as I done as much research as I can.
Topless and getting my degree
06-10-2019, 08:55 AM | #61 |
Rep 247
I use the under hood connections for charging while stored so it would make sense to use them if I wanted to maintain power while swapping the battery.
That being said, I had no issues simply swapping the old to new battery a few years ago without having power connected as I think you/ that tech suggested. Maybe I got lucky, but I also had not read/heard about any need to do so except for that earlier post. |
JJZ4MR30.00 |
06-10-2019, 05:24 PM | #63 |
Rep 194
Thanks
Thanks for the responses guys, I just added and edited attachment from what I did earlier today. When you say " posts " I only found one " + " is there a negative post I'm not seeing ? My group 47 650 CC charged back to 12V at OReillys, no charge. I'm about to go do the install and hopefully that was that. I killed it by putting the top up and down several times while not running, while I was doing a five day process of leather restoration using Leatherique....Man are my seats soft and beautiful right now. Of course I did not discuss this with the guy at O'Reilly's
06-10-2019, 05:27 PM | #64 | |
Rep 194
Read this earlier
07-01-2019, 12:42 PM | #65 |
Rep 232
I replaced the battery in my '06 Z4MR this past spring. It is a pain because of the confined space and the lack of knowledge on the two nuts on top of the battery support bracket. I recall searching all over until I found a YouTube video that illustrated it. I have seen this come up too many times now that I will consider making a very detail video on the battery replacement procedure for the Z4M.
'06 Z4MR
Black sapphire / Imola |
08-10-2021, 01:53 PM | #66 | |
Rep 1
