      09-16-2010, 03:57 PM   #1
2288
Anyone remove the glove compartment to access fusebox?
I'm trying to access the fusebox which is located behind the glove compartment. How difficult it is to remove the glove compartment?
      09-16-2010, 06:06 PM   #2
chickdr
Drives: 2006 M Roadster
Easy. You don't have to remove it, just release it to allow it to swing down further than normal.
      09-16-2010, 07:48 PM   #3
2288
LOL seriously? I'll try as soon as I get home
      09-16-2010, 07:49 PM   #4
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Yea there's some retention things you push in.
      09-16-2010, 08:01 PM   #5
Ron Stygar
Drives: 2006 Z4 M Coupe
It's in the owners manual under fuse.
      09-17-2010, 11:15 AM   #6
bluesandbmws
Drives: 2007 M Roadster - Imola/Red
Two things you'll need if you're going to do anything with the fuses
1 - a flashlight
2 - a computer printout of the fuse locations/functions - it's not in the manual but you can find online.
      09-17-2010, 12:43 PM   #7
Thisisdudewhoru
Thisisdudewhoru's Avatar
Drives: 16 BSM 340i
There was a sheet that laid out where and what every single fuse was in my fuse box area in my 07 z4mc.
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake.:.H&R Sport.:.
      09-17-2010, 01:02 PM   #8
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
Push in two tabs on the bottom. The glove box will disconnect further than usual, revealing the fuses. Fuse map is tucked in there behind a little pocket. Good luck.
      09-20-2010, 06:06 PM   #9
nadaclue
Drives: Urban Green 2003 3.0
Once you push in the two retaining tabs on the top of the glove box and let it swing all the way down, you can just pull the glove box off as well. It's just held on by two plastic C brackets over a metal rod, the tension in the plastic is the only thing holding it there. When you're done, just clip it back on and push the glove box all the way up and you'll be good to go
I just did this two weeks ago, I wired my radar detector straight into the fuse box. There should also be a small card next to the fuse box that you can take out and it shows what all the fuses are for.
      09-21-2010, 10:23 AM   #10
2288
thanks everyone, this is exactly what i plan on doing. i went to autozone this weekend to pick up the add-a-fuse to use with the escort direct wire. is that what you did as well?
      09-21-2010, 11:23 AM   #11
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
Yes, that's what I did. Works great.
