01-05-2011, 12:52 PM | #1 |
John 14:6
59
Rep 587
Is a 03-06 2.5i air filter box the same with a 3.0?
Unfortunately Dinan no longer makes the High Flow Intake for a 03-06 2.5i, but they still make it for the 3.0 (part # D760-0011) . I tried doing some research to compare whether the air filter box (lid) is the same for a 03-06 2.5i and 03-08 3.0, but wasn't able to locate part #s. Do any of you know if the air filter box is the same for a 03-06 2.5i and 03-08 3.0? I really want a Dinan High Flow Intake .
http://www.dinancars.com/shop/D760-0...05.aspx#page=1 TIA
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover... |
01-05-2011, 01:31 PM | #2 |
Rep 1,224
Is it possible to retrofit the entire air box with a Dinan top from an earlier car into a later model? Would one expect an increase in flow with a retrofit box in a 3.0 Si car? The Dinan air filter visually appears to have much greater surface area then the oe filter (= greater flow with acceptable filtration). Any issues with the MAF?
TIA
01-05-2011, 02:30 PM | #3 | |
Rep 12,565
01-05-2011, 05:50 PM | #4 |
John 14:6
59
Rep 587
I finally found the info on realoem and it appears they have different part #s for the air box, air mass meter, and misc parts . It looks like it requires replacing a lot parts to retrofit the 3.0 intake to get the Dinan High Flow inake to fit
01-05-2011, 06:02 PM | #5 |
Rep 12,565
if you can spend 7 bills on emblems, you can surely drop 1100 on a gruppe m intake
01-06-2011, 09:41 AM | #6 | |
John 14:6
59
Rep 587
However, maybe on an exhaust
