      07-11-2009, 04:03 PM   #1
jonanator
Drives: '08 E93 335i, '06 Z4MC
HRE C20 Fitment
I remember seeing some gorgous HRE C20's on a black Mcoupe. Was the username Moupe? I have wanted a set ever since!!
Does anyone know what fitment specs his C20's were? I found a set for sale, the specs are:
Rears: 19x10.5 Toyo Proxes T1R 285/30-19
Fronts: 19x9.0 Toyo Proxes T1R 245/35-19
Will that fit or are the rears too wide?
Thanks,
      07-11-2009, 05:38 PM   #2
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
E46 fitments normally work well. Depending on the rear offset it may be tight on a coupe with a 285, but some tires will work at this size. HRE does not normally release their offsets as you order "per vehicle". If you find out what the tires were originally ordered for and give HRE a call they will be able to confirm fitment on the Coupe.
      07-11-2009, 06:10 PM   #3
Alpine M
Drives: Silver/Red Z4MC
E46 fitments are not the same as Z4, specifically the front offset.
These are what you need ... sent you a PM
[IMG]ftp://turboneticsownersclub.net/Bimmerfest.jpg[/IMG]
      07-11-2009, 06:55 PM   #4
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
Correct, you will likely need front spacers. That being said with this car you will need spacers either way unless custom ordering the wheel specifically for the vehicle to get a flush fitment.
      07-21-2009, 11:06 PM   #5
aus
Drives: Odysse
When you guys say E46 fitment, do you mean E46 M3 or non-M3 fitment?
I think I've seen 335 wheels on these cars too... with spacers of course? Has anyone else seen this?
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
      07-22-2009, 08:39 AM   #6
epbrown
epbrown's Avatar
Drives: BMW M Coupe, Porsche Boxster S
Z4M, E46M, and E90 3-series use the same offset, last I checked.
      07-22-2009, 01:21 PM   #7
SunnyD
SunnyD's Avatar
Drives: M4 GTS
I could've sworn he was running 20's, but c20's are hot on the m coupe!
'16 ///M4 GTS
'11.75 ///E90 M3 ZCP | DCT
'06 ///M5 | SMG - Gone
'98 ///M3 | 5MT - Gone
'07 ///M Coupe | 6MT - Gone
      07-25-2009, 08:11 PM   #8
aus
Drives: Odysse
Thanks. That opens up a lot of possible wheel choices.
      07-29-2009, 07:02 PM   #9
fitchesbass
Drives: BMW
E46 and E46 M3 are two different offsets as others stated. Make sure to specify.
The primary difference is the rear wheel offsets for the E46 M3 / Z4M compared to the regular E46.
Also Z4 offsets do not equal Z4M offsets.
